Question about Craftsman 2700 PSI Briggs Stratton Powered Pressure Washer
Will not shut off have to run it out of gas - Craftsman 2700 PSI Briggs Stratton Powered Pressure Washer
  • 28 Answers
Make sure to use something insulated if you are going to short the spark plug to the engine. I got the shock of my life doing that on a lawn dethatcher.
Posted on Apr 16, 2015
  • Craftsman Master
  • 1,977 Answers
It won't shut down because the gizmo that shorts the spark plug is not working. If possible take an insulated screw driver and either pull the spark plug wire off the plug or try to touch the end of the plug and the engine at the same time. If the switch is in the gas lever there may be an adjustment on or in it that shorts the plug out.
Posted on Apr 13, 2015
Gas in oil on a 23 horse brigs
If you are speaking a lot of gas..you have a sticking float in the carb bowl..at the bottom of the bowl there is a electrical positive shut off device..it is designed to stop gas from flowing out to the ground when the float sticks..unfortunately it then allows gas to go back through the intake and eventually into the cylinder and engine block..you can fix but will happen again so my suggestion for a never fail again is to MAKE SURE THE FUEL SHUT OFF IS SHUT OFF every I mean every time the engine is stopped..This will assure gas will not flow out of the tank when not running..if your mower does not have one..put one in the line between the tank and carb. Where you can get at it easly..one more thing I suggest when shutting the mower down for a period of time let it run for a while AFTER CLOSING THE SHUTOFF VALVE EVEN LET IT RUN OUT OF GAS this will make sure gas left in the carb will be used up and none will find its way to the block..make sure you chage the oil,filter and clean the plugs and cylinders to eliminate any existing gas in the oil system..it may burn white smoke for a little while from being in the muffler..but should clear up...REMEMBER SHUT GAS OFF EVERY TIME THE EGINE IS NOT RUNNING..and no more gas in oil...Good luck..
Feb 21, 2015 | Garden
Mcculloch MB3202 32cc gas blower it will run for 10 to 20 mins or so then shuts off it seems that it's getting to warm then shuts off it will start back up but then shuts off again. Why is this doing that?
You could be running the oil gas mixture with not enough oil. The high speed jet could be running the engine lean. The cooling air thru the engine could be blocked by debris/leafs.
Oct 21, 2014 | Garden
I have a Vaillant Thermocompact VU182 E boiler. Functioning ok except that when room stat. or cylinder stat.shuts of gas the demand light continues to glow and pump keeps on running. Main switchboard has...
Pump should keep running long after gas shuts off, because of residual heat. It is most efficient to shut gas off as quickly as possible, and run off retained heat.
Oct 13, 2013 | KDS Valiant 6380iPTD-01 Notebook
Shutn off while stopped
not good to run low on gas you might have sucked trash into fuel line check fuel filter and stop and going will make what gas is in it to slosh around in tank
Oct 02, 2013 | Cars & Trucks
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Can't get gas into my 2002 Hyundai Accent.
The reason the gas station pump shuts off is when the fuel reaches the tip of the gas nozzle, so when you are filling your car and the gas nozzle (gas stations pipe) keeps shutting off it means that the pipe that runs to the gas tank is not open completely, what happens is when you pump the gas in the car the supply pipe from the gas tank opening to the tank fills up quickly and this causes the gas station pipe nozzle to shut off, have some body take down the gas tank and have a look at the gas tank opening and also gas supply pipe that runs from the gas filler opening ( on the car body) to the gas tank. Have a look at it and please don't forget to rate the answer if it was helpful, thanks!
Mar 25, 2010 | 2002 Hyundai Accent
Bosch WTMC3500UC gas dryer runs but does not heat
my dryer does not put out lint, rather thru the front.
Aug 22, 2009 | Bosch Dryers
Mower runs for 10-15 mins. then shuts off.
Check your gas cap. There must be a vent for the gas to flow joedog
Feb 26, 2009 | John Deere Garden
Gas dryer
If when you run it you smell gas stop running it!
You should shut the gas valve off immediately!
If the gas heater isn't working when your running it it's probably the Valve the activates the gas (Selenoid) or the Ingnitor that lights it!
Jan 20, 2009 | Kenmore 73952 Gas Dryer
Craftsman 2700 PSI  Briggs Stratton Powered Pressure Washer Logo
88 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
