When I look at the face on the cordless phone it is to dark to read the information on incoming calls
SOURCE: vtech cordless phone/ detc 6.0
This worked for me. Unplug the power to the base for 10 seconds then plug the power back in. That did it for my "connecting....." problem. Good luck!
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
my vt phone is lock and need to unlock it help
SOURCE: Telstra V580a cordless phone not working.
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect.
Good Luck
Doc
SOURCE: panasonic cordless phone model kx tg3521 is keypad
panasonic cordless phone model kx tg3521 keypad locked .I can attend incoming calls but I can't do outgoing calls .its say dial is locked
