Question about Yamaha RX-A720 Aventage 7.2 Ch. AV Receiver
Sound is intermittent.
My sound keeps coming and going for no reason. I checked all the connections and everything is fine. Sometimes I have no problem and other times the sound will go off for a few seconds then come back on.
2 Suggested Answers
  • 87 Answers
SOURCE: The auto set up keeps saying the phase is reversed
Reverse the connection on one of the speakers and see what happens.
Posted on Nov 01, 2009
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
2004 Toyota Corolla Verso has intermittant sound and control problems. The radio will play fine and suddenly the sound will go off as well as the back lights illuminating the radio face and knobs.trying to...
The problem sounds like intermittent power supply. There might be an inline fuse which sometimes does cause problems. Remove the radio and check the power line to see if there is such a fuse. If so, remove and clean it with a bit of sandpaper, put it all together and see if it helps.
Sorry, can't be more helpful.
Aug 29, 2017 | 2004 Toyota Corolla
Automatic headlights don't work all the time on 1999 Buick Regal GS with 144,000 miles. Intermittent problem. Sometimes they work and sometimes they don't. I always keep headlight switch on middle...
hi,
you had specified as, the headlights are not working properly & making a buzz sound.The problem is the circuit has a loose connectivity either at the switch or near the bulb. while you are able to hear the buzzing sound check the position of the wires near the source of sound. You will be able to find where the connectivity should be tightened exactly.please do this as early as possible since the loose connection can damage the circuit and the switches due to high temperature.
thanks, have a nice day.
Feb 09, 2010 | 1999 Buick Regal
Intermittent sound with cbl/sat. Sometimes sound
Your receiver is HDMI version 1.1,1.2 or 1.2a and just don't work with anything to be honest with you. It's an HDCP (copyright Issue) and 5v pass thru issue. and the list goes on. If you can, just run HDMI directly to the TV and optical or Digital Coaxial to your receiver for audio and all will be well again. If you need more help, just post a comment and I will gladly help some more
Jun 24, 2009 | Onkyo TX-SR875 Receiver
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
PICTURE AND SOUND KEEP GOING OUT AND COME BACK FOR 30 SECONDS
One of the power supply areas are most likely going intermittent. This can be from cold solder connections on the circuit boards, or from some components failing due to age.
An experienced tech should be able to service your set, but it will be expensive for the time involved. Sometimes these types of faults can be very time consuming to resolve.
Jerry G.
Nov 21, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Intermittent sound
I have notice that on some connections the speed is not fast enough to handle cam and voice at same time, If its not connections speed. He can go into control panel and run sound check for mic. It may help solve any problem if it's in the Audio drivers, And if that still does not help try a different mic. and see if that works. Hope that helps you out some what. Thanks
Jan 05, 2008 | Logitech QuickCam Communicate STX Personal...
Old Hitachi sound...
unplug the dvd in to the tv, see if u have sound then...gotta read the manual. go into menu and see if what the sound is.. u might have to switch it to tv stereo or mono. gotta read the manual good luck
Jun 30, 2007 | Hitachi C25-RF35S 25" TV
Daewood tv model # dtq-26s1fc
you are having a intermittent sound problem probably some lose solder or in the audio circuit.take the set to a tech to have it repair.good luck.
Dec 20, 2006 | Daewoo DTQ-26S1FC 25" TV
Yamaha RX-A720 Aventage 7.2 Ch. AV Receiver Logo
59 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
