Question about Toro Garden
Can the plastic impeller on a model 51591 be replaced with a metal #100-9076
    Top Expert:
  • Toro Master
  • 44,580 Answers
Probably but the problem will be when vacuuming
plastic impellers absorb shock from stones and other hard objects, where as metal blades will break off causing an imbalance of the impeller
Posted on Apr 13, 2015
How to replace plastic impeller with brass(metal) impeller
I called Lowes then Utilitech and they sent me a new impeller. There were no instructions about how far to thread the impeller onto the post. I am going back in to thread it all the way to the top. I wish I had requested a brass impeller.
May 21, 2014 | Utilitech 1-1/2 HP Irrigation Pump UTP15P1
How do replace the impeller on a toro 51591 super blower vac?
Toro and Sears blowers are pretty much the same. It is not worth the trouble to replace. Good Luck
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
If i find metal shavings around the pully do i need to replace the water pump?
Sometimes a water pump will fail internally due to severe corrosion wearing away the impeller blades, or the impeller comes loose on the shaft, or the shaft itself may break from metal fatigue (caused by flexing due to an out-of-balance fan).
Many late model vehicles (Chrysler in particular) have plastic impellers to improve cooling efficiency and to reduce cavitation (drag). But the plastic can wear down quickly if the coolant is dirty and contains abrasives. The pump may not leak, but it may not circulate enough coolant through the engine to keep the engine at normal operating temperature.
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because teh hose willb e HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
Test it and tell us news (remember rated this).
Jul 07, 2010 | 1998 Buick LeSabre
Water pump impeller query
Hi my name is Tom and I am here to help.
All impeller blades are made of plastic. This way they will keep a tight fit on the inside of the water pump. Metal would not be able to do this.
TomE
Jul 04, 2010 | 2002 Audi A4
Need impeller # 100-9068
Here you go. $11.99 on EBAY right now:
http://cgi.ebay.com/100-9068-Toro-Impeller-for-51591-51573-51552-Fast-Ship_W0QQitemZ370301014626QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5637a91262
Dec 29, 2009 | Toro "Toro" Super Blower/Vac
Diagram for 2001 jetta 2.0. water pump needs replaced. where is it?
The water pump is driven off of the timing belt. Might as well do T-belt and access. while you are in there.
Oh, and make sure the replacement pump has a metal (brass) impeller. The factory pump has a metl shaft w/a plastic impeller. Once in a while these cause somebody a headache when the impeller seperates
Dec 24, 2009 | 2000 Volkswagen Jetta TDI
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
Nov 13, 2009 | Toro Blowers Rake and Vac - Electric...
Sm.piece broke off spinner wheel; result motor not balanced
yea if you cant fin da company to order the part form which you probably cant youll have to trash it.
Jan 09, 2009 | Toro Super Blower Vac
Garden Logo
166 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
