Question about Badger 1 All Insinkerator 76039h 1/3 Hp Feed Garbage Disposal Black Opened
Leaking from bottom and sides - Badger 1 All Insinkerator 76039h 1/3 Hp Feed Garbage Disposal Black Opened
FRS26KF6EMB
The water valve sounds like it may be leaking and the drain hole is plugged if this is a side by side the drain is in the very bottom back. sounds like it is actually a two problem situation you have. watervalve bottom back outside frige and drain in the back bottom of freezer.
Sep 23, 2012 | Frigidaire PLHS267ZA Side by Side...
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Badger 1 All Insinkerator 76039h 1/3 Hp Feed Garbage Disposal Black Opened Logo
407 people viewed this question
Top Badger Home Experts
Donni Steen
Tom Chichester
Are you a Badger Home Expert? Answer questions, earn points and help others
