Question about Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os Tablet
My tablet screen is frozen on the screen that reads azpen.when i turn it off and back on it is still frozen.it will not take a charge nor if i leave it on will the battery die.what can i do?
    Scholar:
  • 172 Answers
Hard Reset
Press Vol-up&Vol-Down button at same time, Then press the power button.
This starts your devices Recovery Mode.You can do a Wipe/Factory Reset from there. Use the Vol Up&Down buttons to navigate and the power button to select.
Be Careful and DONT MESS with the Other options or you may Brick your phone.
Posted on Apr 13, 2015
My tablet fell the next day the buttons were frozen.what should i do?
I would take it in and get it looked at. It is possible that the unit has been damaged and can be fixed.
Jun 02, 2016 | Azpen 7" 4GB Tablet Capacitive Android 4.0...
Azpen A700 tablet. Why won't it charge or turn on?
If your Azpen A700 tablet won't charge or come on, you got no result trying to reset it, you've got only one option: take it back to the shop where you bought it and ask for authorized repair service, to diagnose cause of failure You even may have still option to warranty service.
Problem is that it's a low cost 35$ tablet so repair service might not be worth to pay, looks rather as a disposable device..
Aug 05, 2015 | Tablets & eReaders
How do you use a USB cord to charge a azpen 13.3 when the normal charging way is broke
I don't think you can. The USB port is meant to go out of the tablet and the charging port brings the charge in. Unless the Azpen is different from many other tablets.
Mar 19, 2015 | Tablets & eReaders
Problems with Azpen A727 tablet.
Soft Reset Press the reset button on the back of the tablet with a fine point object for about two seconds. This will not erase data store on the tablet. This may help if the screen is frozen or not responsive to touch.
Nov 24, 2014 | Tablets & eReaders
Azpen tablet will NOT CHARGE.
No way. Even to change usb port sometimes impossible on cheap tablets. But you can try
Dec 01, 2017 | Nextbook Premium 7 Capacitive Touch...
Frozen screen
The app has crashed.
Try performing a power reset. There should a power reset button near the charging port.
It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button
inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours
before using it. If you leave it on the charger for longer than the allocated time, you will go
back to having the same problem as before.
Support Troubleshooting Guide
Jan 22, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
How do I get Tablet fix it will not charge?
The mini USB cable that came with my tablet was lame and would only charge if held at a certain angle. Another cable worked fine. This is an ultra cheap tablet, and they cut corners everywhere they could.
Jan 09, 2014 | Azpen A9 Android Tablet
My visual land tablet is frozen on the lock screen, it want slide to unlock the screen, what should I do
follow this steps and fix it. GOd bless you
Press the power button. Hold it for 20 seconds to force the unit to shut down.
  • 2 Turn the Tablet back on to determine if it is still frozen.
  • 3
    Remove the power adapter or USB cable from the Tablet. Turn it back off. Turn the Tablet over and remove the screw from the back of the device. Slide the battery panel off of the Tablet and pull the battery out of the unit.
  • 4
    Connect the Tablet to the power adapter and power it on. The freezing issue should be fixed and your Table should respond properly. Reinsert the battery and charge it to full before removing it from power.
  • Read more: http://www.ehow.com/how_8722116_troubleshoot-frozen-nook.html#ixzz2aUBnGy3w
    Jul 29, 2013 | Tablets & eReaders
    How do i unfreeze my android tablet
    My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
    Oct 28, 2012 | PANDIGITAL SuperNova
    Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os Tablet Logo
    339 people viewed this question
    Top Azpen Tablets & eReaders Experts
    Da Doc
     Mikey
    Mikey
    ray gallant
    Are you an Azpen Tablet and eReader Expert? Answer questions, earn points and help others
