Question about kawasaki Garden
My Zmaster with 19 horse Kawasaki bogs under a load runs good without blades engaged
    Top Expert:
  • kawasaki Master
  • 45,257 Answers
Check for things wrapped around the blade shafts . stings rope wire etc . quite possibly you have a bearing going bad also
Posted on Apr 12, 2015
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 61 Answers
SOURCE: engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Posted on Sep 06, 2009
SOURCE: Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Posted on Oct 21, 2009
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Toro 52" deck with 19hp kawasaki engine runs fine when not under a load, when blades are engaged the throttle constantly goes up and down. I am assuming it is a governor problem, and have made sure the...
Could also be a carburetor issue, remove air filter and make sure that its not clogged, even try running it for a short time under the same load. If problem persist tske it to rdpair shop bc there are several other issues it could
Aug 19, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
It's a 1993 and it starts idles revs fine. But when u put it in gear it bogs down. Is it jettig or air or what?
First place I'd check is the carbs - make sure the choke isn't engaged!
Choke on = easy start + easy idle + easy revs + bog under load.
Too much air (hole in the airbox, hose off the airbox) can do this too.
Apr 09, 2011 | kawasaki KX 125 Motorcycles
22 horse kawasaki riding lawn mower will not run at full throttle unless the choke is engaged
That is not a good situation. Too rich of a fuel adjustment can wash the bores out on that engine and prematurely wear it out! You will likely need to have the carburetor linkage and plate adjusted so that full throttle operates without engaging the choke. (If this is a single lever that you slide from slow, idle speed to fast, then on to choke)
May 09, 2010 | Husqvarna Garden
14sb engine running when blade clutch is engaged the lawnmower stalls.
Normally I believe this mower to have a Kawasaki engine, and the main jet and 'pilot air hole' need to be cleaned. You are running a lean condition, and when the blade is engaged, the engine does not have enough fuel to continue the extra load. A small test for this is to engage the blade and the choke at the same time. If the engine has enough fuel to continue running and engage the blade, this confirms the lean fuel condition. Cleaning those jets will solve the issue.
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have a LX277 tractor with a Kawasaki 17hp twin. The problem I'm having is the engine bogs down under load. Seems to run fine otherwise. I've replaced the fuel filter, spark plugs, sharpened the blades...
Run some combustion chamber cleaner directly into the carb. It is much better at cleaning clogged jets and orifices than commercial carb. cleaner. Pour in slowly at high idle while it is running. It will smoke like crazy. Bog it right out with the pour then let the machine sit for an hour then run the engine fast to complete the clean. Hope this helps!
Rob
Sep 22, 2009 | Garden
I have Briggs 18.5 horse and after I mow for a while the motor will bog down and quit unless I dis-engage the blades. I removed the spark plug and it looks wet. I replaced it and after a short time again...
If the engine runs ok when the blades are not
engaged then the engine is all right. Maybe its a faulty safety blade switch or a wire to the switch is stripped and is earthing to the body. Stephen
Sep 04, 2009 | Garden
Jun 30, 2009 | Ariens Garden
Garden Logo
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
