Question about Pool & Spa
Pump runs great but when chlorine light switches on it shuts the whole thing off and service light comes on
  • 2,760 Answers
Salt level too low in pool ??
Posted on Sep 05, 2015
4 Suggested Answers
  • 297 Answers
SOURCE: my service light comes on right after the
Service light is only handled by intex.
If you have a valid receipt you can call intex. They will have you fax some info and then send you out a new one.
Posted on Jun 28, 2010
  • 297 Answers
SOURCE: Intex salt water chlorinator I added a higher flow
your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Posted on Jul 14, 2010
jturcotte
  • 8514 Answers
SOURCE: I have a pentair superflo
Could be the motor has packed up. Or, more likely, perhaps the contacts or coil in the timer have failed. That is a big motor, and a lot of current is going thru the timer contacts. Can you apply voltage directly to the motor? Do you have an AC voltmeter to check the power from the timer with?
Posted on May 15, 2011
Intex saltwater pump - runs for 3 minutes and shuts off with service light coming on.
It's overheating internally. Overload switch is either doing its job: tripping out when motor overheats, or the overload switch is faulty and has failed.
On either situation = New Pump
Why ? You ? Ask?
Because Intex Sells NO parts for their components!
They want you to buy a whole new unit.
They are not made with quality in mind. Greatly mass produced in China, and unleashed on the world by the Gazillions.
Thats what happens with Toy Equipment.
Plus, the adage of old rings so true...
You Get What You Pay For
A real Pool Pump with a real pool Filter, will cost you more, but will last you longer.
Jun 13, 2015 | Intex Pool & Spa
Just purchased and installed Intex salt water system. It shows low flow and now, after 5 days of installment, the water is completely green (expecting Swam Thing to come out!) I need your guidance to...
Seems like you may not have the pump and the salt chlorinator in sync... If your water is dark green and not a big pool, you may want to drain and refill, if you have a large pool, you may want to shock and then try the following...
1.Make sure you have added the correct amount of salt...
2.Set your timer for your pump for 12 hrs.
3.Wait 15 minutes and then turn on your intex salt water system..
4.Set you hrs of operation on your salt water system for 10 to 11 hrs...
5.After running the system for 3 days, check your chlorine level..
If water clears and chlorine level is high, adjust the time.. You will have to re-sync the pump and chlorinator.. If the pump turns off before the chlorinator finishes it's cycle, you will get a "LOW FLOW" alarm..
I hope this helps and good luck.. Please rate and comment on the information provided.
Jul 26, 2011 | Intex Automatic Salt Water System for ...
My Krystal Clear Deluxe Saltwater System Model 8110 is not turning on
My pump works, but it wont turn to chlorine, so it then turns the water green, i looked everywhere and cannot find a solution, anyone that can help that would be great.
Apr 23, 2011 | Intex Automatic Salt Water System for ...
When i turn on the chlorinator its comes on and then turns the power off to the whole unit
Please dragon, Be careful. If the chlorinator is not wired to the unit correctly you could ven have a
flash!! 1. Shut off the circuit breaker located on the house. Ir's located in
metal rectangular panel. Probably next to the elect meter.
2 Now that the power is off check the wiring where the chlor attaches to the pump.
The wires should be color coded. Black & red are always the hot leads, white & green are
neutral leads, Let me know........dansky66
Mar 26, 2011 | Intex Automatic Salt Water System for ...
Chlorine generator not working(brand new)
Super shock your pool ... take it to around 20 ppm CL using liquid or powdered CL. Brush your pool daily for several days ... run your filter at least 16 hours a day ... 24/7 would be better. Maintain 5 ppm CL and brush weekly after you get the algae under control.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
My service light comes on right after the chlorinator light comes. And when the service light comes on everything shuts down.
Jun 27, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
System shuts off and will not chlorinate
check or replace sensor and check cell if ok possible bad transformer
Jun 20, 2017 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
109 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
