Question about Tablets & eReaders
It is an a97 and battery will only charge to 9% could it be the battery and how can I get a new one
The charger is good
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 172 Answers
You can get a battery from amazon.com
or eBay.com
Go on site search for the battery and they will have different buying options.
New,Used ect..
Amazon also has a trade in program that any electronic no matter how old or damaged they let you trade it in for a gift card. Amounts vary.
Get a new battery and trade in the other for money. Can't lose there.
Posted on Apr 12, 2015
My Irulu 9" tablet I got new. I had it few months is now acting up bad.It only comes on when I plug it up on charger
change the battery
it probably is defective or has developed a memory level for charging when not real low
Oct 01, 2016 | Tablets & eReaders
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
Why won't my Battery charge.
unfortunately batteries go bad too like everything else.
have you tried a different charger?
Jan 24, 2015 | Proscan PLT 9 TAB 9-Inch Tablet Black
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Tablet Charger is 400mAh, Tablet Battery is 4000mAh. Is my charger sufficient ??
Yes, ideal. 10% of battery capacity is the recommended amount.
Apr 07, 2017 | Tablets & eReaders
TC4400
How do you know the battery is good? does the multimeter really read more than the battery should give, according to what is printed on it?
A 3,7 volt battery, should give at least 3,8, wham not connected. A 7,2 at least 7,4. Because the printed voltage should be on the connector, when you are discharging the battery.
When your charger is blinking, it could indicate the battery is not well. The Ri can be to high or something else, is wrong, and that is ht the charger won't or can't charge.
Jun 09, 2014 | Compaq tc4400 Tablet PC
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My Galaxy tab 7.7 wont charge, I tried to charge it yesterday when the battery was still 50% charged but now it is down to 15% and my tab won't charged. I am using the original charger, please help!...
my mama said that mayb ur need a new charger cuz Samsung is sending me a new 1 and I think that\'s y. I hav a 7 inch tab 2 n I love it but it stop charging so I don\'t no whats wrong but im getting a new charger so its all good and guppy now :) ill keep u updayted cuz I think its the chargers falt not the tablets!! idk if not then ill just reset my tab and cry my eyes out cuz that sucks big time I meen really who wanna reset there tablet? not mee! but what the hell..mayb a new charger will help the little baby...
Jan 23, 2013 | Samsung Galaxy Tab 7.7 P6800 3G 16GB...
My iPad 3 battery is charging slowly how do I speed it up?
Make sure you are using an authentic charger if that doesn't help update your ipsw to the latest firmware
Apr 18, 2012 | Apple iPad HD
Tablets & eReaders Logo
61 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
