Question about Husqvarna Garden
Husqvarna 50 chain keeps coming off - Husqvarna Garden
  • Husqvarna Master
  • 1,169 Answers
If you recently swapped chains did you put on the correct pitch? Normally this saw uses a .325 chain; unless, someone has modified it to use .375 (3/8)
Posted on Apr 13, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Are you adjusting the chain tension correctly?? Make sure the bar in installed correctly with the tension adjustment pin in the appropriate hole. Elevate the tip of the guide bar while adjusting the chain adjustment screw until the chain is snug but not tight. Then tighten the bar bolts without lowering the tip of the bar. Also ensure the drive links are engaging the sprocket correctly.
If the chain is adjusted correctly and the problem still exists, remove the sprocket side cover, bar and chain and inspect the sprocket for extreme wear. Once the sprocket is worn excessively it won't want to engage the drive links of the chain correctly which could be the source of the problem. If so, replace both the sprocket and the chain because the excess wear of the sprocket could have damaged the drive links of the chain and putting an old worn chain back on with a new sprocket will cause the new sprocket to begin wearing prematurely.
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
254 husqvarna chain saw mixture and plug gap
Plug gap 0.5mm, fuel oil mix 50-1 with Husqvarna two stroke oil, or 25.1 with other makes of two stroke oil as the quaility is not known
Jun 14, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the fuel & oil mix for a chain saw
Husqvarna chainsaws run at a 50-1 fuel oil mix with Husqvarna two stroke oil, with other two stroke oils they recommend 25-1 fuel oil mix as they do not know the quaility of other manufacturers oil, always try to use Husqvarna oil.
Sep 25, 2011 | Husqvarna Chain Saw 20" Bar
Oil mixture for husqvarna 141 getting to answers 50:1 or 40:1
What Husqvrna say is 50-1 withe Husqvarna two stroke oil, or 40-1 with other brands of two stroke oil, this is due to not knowing the quaility of other oils.
Sep 20, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What kind of oil do I need to use in my husqvarna 16" chain saw?
Unleaded fuel with Husqvarna two stoke oil mixed at 50-1, for the chain you need a non fling chain oil, both should be available from your local Husqvarna dealer.
Aug 21, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I thghten the chain on my 154
loosen the 2 13mm nuts at the base of chain bar. rest the other end of the chain bar on a block of wood to keep tension correct. the adjuster screw is on the other side of the chain bar to the 2 nuts you just loosened. turn it clockwise until free play is removed but but no more. tighten nuts back up. job done.
Aug 09, 2010 | Husqvarna Chain Saw Handle Models 50 51...
I have a husqvarna model 50 chain saw and am not sure of the ratio of the oil & gas mixture.
Husqvarna Rancher 50 1982-11 OM Follows:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS1982/HOUS1982_O8200003.PDF
50:1 according to your manual if using Husqvarna (quality) 2-cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 01, 2010 | Husqvarna Forest & Garden No.967012396 345...
Fuel mix ratio is it 50 to 1 on husqvarna 455 rancher ?
Yes, for all Husqvarna chain saws the fuel to 2 cycle oil ratio is 50:1.
If you'd like, I've provided a link to the Husqvarna website where you can get a free download of the user manual and guide for your chainsaw, which is very helpful offering tips for using and maintaining your chainsaw, etc.
http://www.husqvarna.com/us/forest/support/download-manuals/?query=455&types=O
Just select your particular model/year and click on the link to download and save a free copy. I find keeping a file folder on my computer is a great way to store all the manuals and guides for my personal tools, appliances, and lawn equipment, etc., so I'll always have them available for future use and reference.
Hope you find this information Very Helpful and best regards
Oct 22, 2009 | Garden
Chainsaw Service manual for Husqvarna in New Zealand
here's a Contact in your Area:
Husqvarna New Zealand 15 Earl Richardson Avenue, Manukau City Auckland
Auckland
New Zealand
Tel: +64 9 920 2410
Fax: +64 9 920 2429
Web: http://www.husqvarna.co.nz
E-mail: carol.osborne@electrolux.co.nz
Nov 17, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
106 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
