Question about ZTE Cell Phones
Im trying to repair a ZTE Z998 phone. how do i take the inside apart without removing the screen
The charging port is broke and i am trying to fix it, but i cannot get the back of the phone apart
SOURCE: I'm trying to disassemble my
that for the lg chocolate slide, I'm in the same situation as you, any help would be much appreciated.
Posted on May 21, 2008
SOURCE: How Can I Take Apart My Samsung SCH-u740?
To take off housing, you need to pry off plastic piece on end just above camera lens. Then you have to remove one philips screw. After that, you can pry case open. I use a tool that they sell to replace Ipod batteries.
Posted on Feb 20, 2009
localwonder
  • 6784 Answers
SOURCE: Won't Charge! :-(
Hi. these situations are mostly caused by a bent or broken copper prong that is located within the input charger port that is inside the phone housing.
When you insert the charge cord into the input port, there are copper prongs that will have to connect to each other and , this contact point will transfer the necessary current to the cell for a proper charge.
If the prongs are damage in any way due to broken copper or, bent copper prongs, this will prevent the necessary current from flowing to the cell.
Most remedies are crude like using a tooth pick or paper clip to straighten out the prongs inside the port. these methods do more harm than good and i recommend sending this phone in for a input port transplant. the manufacture or local repair depot is the best repair solution for this situation.
There is one thing that i would do before sending it to the repair depot. try using a completely different battery cell. if you purchase a new battery and the charger continues to not charge, this will confirm the input port failure.
Please rate and god bless:)
Posted on Apr 22, 2009
maverick218
  • 61 Answers
SOURCE: charger port on LG shine broke.
It could be either your charger is broken or the charging port in the phone is- I would recommend taking it to a store and have them check it out for you.
Posted on Jan 31, 2010
SOURCE: lg rumor charging port wires broke off from port to phone
Ok same think happened to me and i found a temp solution this really works :D http://www.youtube.com/watch?v=9pYcgmLhUcQ
Posted on Oct 05, 2010
How do I unlock my Z998 ZTE I forgot the password
Factory Reset, scrub the whole thing clean.There is no master code or a way to find the code YOU put in it.
Power Down. Hold Volume Up and Power button until you see the Recovery Console.
Jan 09, 2017 | ZTE Cell Phones
How can I fix my ZTE max Grand charging port
The charging port is soldered to the main board it will have to be repaired by a technician.
Feb 02, 2016 | ZTE Cell Phones
My zte maven won't turn on or charge
If your chargers a loose in the phone, that a part in your charging port broke off and it is cheaper to buy another Maven.
Make sure it is not your charger by using other ones to charge.
Remove the battery and plug the charger in, if your phone works without the battery then you need a new battery
Take the battery out for 10 seconds and put it back in, now try charging it.
If non of these options work for you, then your phone is most likely defective and it would be best to look into another phone. The good news is that if you get another Go-Phone or any other AT&T phone, all you need to do is take your sim card out and put it into the new phone to activate it. This means the phone will work right away and you will be able to keep your remaining air time and phone number.
Feb 02, 2016 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
Where is the serial number on my ZTE-Z990G cell phone?
How to find the IMEI Serial Number of your ZTE Z998
step 3 shows how to remove cover and view ser.#
press the helpful button
Dec 04, 2015 | ZTE Cell Phones
How do I fix a cellphone that won't charge at all when it is plugged in. I've tried turning it off, taking the battery out, and everything.
It could be a problem with the female usb port on your phone. Try shining a light inside where you plug it in and see if there is anything there. Here are a few phones with the female ports where you plug in your charger.
25894004-w32j5maowckw4u0pbavragxd-2-0.png Use something like a toothpick to clean out inside there. If you use something too hard, it can damage the inside of the port.
If there is nothing in there, it could be the cord. Have you tried multiple cords and cubes (wall adapters)? Here is the iPhone version, but really all that changes is the business end of the charging cord, so it still applies.
25894004-w32j5maowckw4u0pbavragxd-2-1.jpg If you have tried multiple combinations of cords and wall adapters, then it might be that the charging port on your phone is broken and needs repairing. A sign of this being the case could be the cable being able to wiggle around too much when plugged into the phone.
If these other solutions do not work, you may need to replace the female micro/mini usb port in your phone, which could be above your skill set and you may need to hire a professional, or someone who knows their way around a soldering iron.
Oct 05, 2015 | ZTE Cell Phones
Grand Max. How do I repair/replace charging port?
should be under warranty if only 3 months old call Manufacturer . if you or someone else messes with it they might not replace or repair it at no cost .
Feb 24, 2015 | ZTE Cell Phones
How do I unlock an ATT ZTE Z998 Mustang
you can easily get AT&T ZTE Mustang Z998 IMEI Unlock Code from zteunlockcodes.com, i got a very fast response and easy solution to unlock my ZTE phone and i found it to be the cheapest way to unlock my phone
thank you zteunlockcodes.com
Oct 09, 2014 | ZTE Cell Phones
How do i reset my camera on my AT&T ZTE 998 Gophone
Try going to the manufacturers website and look for updates. Phones are just mini computers now.
Sep 20, 2014 | ZTE AT&T GoPhone Z998 Prepaid Smartphone
At@t zte z998 screen frozen
Hi it's looks like your phone digitizer is faulty and need to be replaced.
Apr 16, 2014 | ZTE Cell Phones
Cell Phones Logo
144 people viewed this question
Top ZTE Cell Phones Experts
john smith
Nyte_Ryder
vince
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
