Question about Dodge 1997 Ram 1500
Can you buy the filter separately from the pump on a 97 dodge 1500
  • Dodge Master
  • 4,977 Answers
If you mean the fuel filter then yes if you mean the filter sock on the pump then you might find a supplier. you will have to call different auto parts places. you may have to go to the dealer for the pump sock.
Posted on Apr 18, 2015
SOURCE: fuel problem in 97 chevy truck 1500
your fuel pressure regulator could be bad also check fuel pressure with a guage it should be about 55 to 65 pounds
Posted on Aug 28, 2008
SOURCE: I have a 97 Dodge Ram 1500 5.2 that wont start
COULD BE A BAD FUEL PUMP EVEN THOUGH ITS NEW, TRY THE FUSES IN THE MAIN FUSE BOX UNDER THE HOOD, ALSO TRY DISCONNECTING THE BATTERY CABLES FOR ABOUT 5 MINS, LASTLY IT MAY BE THE ECM [computer on fire wall]
HOPE THIS HELPS SOMEWHAT
Posted on Mar 09, 2009
motor1258
  • 6674 Answers
SOURCE: no fuel
In top of tank.
Posted on Apr 19, 2009
motor1258
  • 6674 Answers
SOURCE: where is the fuel pump
top of tank, inside.
  • 38 Answers
SOURCE: transmission slipn 97 dodge 1500
Have you tried calling them to see if they will fix it for free anyway? Sometimes, a reputable service shop will do this or give you a discount, maybe free labor? If they won't give you any help, take your vehicle to Aamco for a lifetime warranty.
Posted on May 27, 2009
Why does my 2012 dodge ram 1500 fuel pump stay on...
About 117,000 results (0.73 seconds) Search Results
    TIPM Repair & Bypass Solutions for 2007-2014 Dodge ...
    www.verticalvisions.com/TIPM_solutions.php
    2011-2012 Dodge Ram 1500; 2011-2012 Dodge Ram 2500; 2011 Chrysler Town ... test your fuel pump relay, and bypass a bad fuel pump relay to stay on the road. .... Mytesting/bypass device will often narrow down your problem to the TIPM ...
    Dodge Ram 1500 Questions - fuel pump keeps running ...
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusNov 1, 2013 - fuel pump keeps running when key removed - 2011 ram 1500 slt quad ...fires right up but will not stay running unless I keep my foot on the gas.
    I Changed The Fuel Pump On My 97 Dodge Ram 1500. Ran ...
    CarGurusI changed the fuel pump on my 97 dodge ram 1500. Ran great for 2 days then stopped running. I can hear pump working, replaced fuel system relay, engine tur... ...Jun 24, 2012 at 03:48 PM about the 1997 Dodge Ram 1500 2 Dr ST 4WD ... The truck fires right up but will not stay running unless I keep my foot on the gas.
    2011 Dodge Durango Fuel Pump Relay Stays Engaged ...
    www.carcomplaints.com/Dodge/.../fuel.../fuel_pump_relay_stays_engag...
Feb 03, 2016 | Dodge Cars & Trucks
97 dodge ram 3.9 stops running while driving. if i sit a minute it will fire back up and run for days afterward....or maybe 10 minutes.
I had to change my fuel pump a second time after just 8 months It has worked fine since. It my be the fuel filter too.
Dec 28, 2013 | Dodge 1997 Ram 1500
Where is the fuel filter on the '97 1500?
i had a 1997 dodge with a 318 ( 5.2 l) thier is no external fuel filter the only one is on the fuel pump in the fuel tank
Feb 06, 2011 | 1997 Dodge Ram 1500 Club Cab
Does a 97 dodge ram 1500 have an engine to firewall ground strap and if so can you describe the whereabouts?
My '97 with the 5.9L gas engine does not. It's grounded from the battery to the frame and a ground strap ran from a bolt under the exhaust manifold on the passenger side(near the oil filter) to the frame
Nov 01, 2010 | 1997 Dodge Ram 1500 Club Cab
I have 97 dodge ram 1500. Once tha truck reaches operating temp. it will stall at idle. Some times you drive it and it runs fine then you stop at a store get a snack and then it wont start with out pumping...
A few things actually lol. How long since its last tune up? A dirty air filter, worn spark plugs and wires and cap and rotor can cause a poor idle and stalling. Not to mention a dirty fuel filter. The fuel filter is in the gas tank unfortunatlly :(
Try giving it a basic tune up " about 45 dollars" and see if that helps. Good luck.
Jun 11, 2010 | 1997 Dodge Ram 1500 Club Cab
Fuel filter removal for dodge ram 1500 2003 model
The combination fuel filter and fuel pressure regulator is used on all engines. It is located on the top of the fuel pump module. A separate frame mounted fuel filter is not used with any engine.
Both fuel filters (at bottom of fuel pump module and within fuel pressure regulator) are designed for extended service. They do not require normal scheduled maintenance.
Mar 22, 2009 | 2000 Dodge Ram 1500 Truck
Mar 06, 2009 | 1997 Dodge Ram
Dodge 1997 Ram 1500 Logo
300 people viewed this question
Top Dodge Audio Players & Recorders Experts
Betty Pearl
Betty Pearl
Level 1 Expert
Jeff Brewster
Jeff Brewster
_-__-___-_
_-__-___-_
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
