Question about Health & Beauty
Charger not working
Only the red light comes on thecharger
  • 68 Answers
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Posted on Apr 14, 2015
I have a Bruno stairlift with a 24 volt charger. The charger will not work. The red light comes on but the green light does not come on
hi
it ether the battery come to the end of the life time
or more likely the diodes have blown in the charger
Jan 10, 2018 | Drills
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Jazzy charge light on chager does not come on
The red light indicates that power to the off-board charger is on. Try a different ac wall outlet that you know works. If a red or green light does not come on you will need to replace charger. Also check the condition of your batteries - dead batteries will not charge.
Mar 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
My E system 3086 ust stopped coming on what coud be the problem thecharger looks oky
Well if the charger looks ok, it doesnt necassarily mean it is, my friend had this problem, what we had to do was test the charger in another laptop to see if it works,in their case the charger was broken, but it may also be that the hole that you put the charger into is broken, have a close inspection of it, to see if anything is out of place, if that doesnt work you may want to consider buying a replacment charger, if that doesnt work you can always get a refund on it. notebooks generally have these power issues, try pushing the charger in fairly hard and keeping the pressure on it, does this cause the charge light to come on? if it does it means that the hole is broken and needs to be repaired.
Mar 30, 2011 | Toshiba Satellite A60-S1591ST Notebook
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
Jan 28, 2011 | HTC Touch P3450 Smartphone
I have brand new just fitted MK Gel batteries and a known working charger. When the charger is plugged in and charging a orange light should come on or green when fully charged. At the moment only the red...
David, If you are not getting the yellow light on the charger then you have a problem with the charger. What voltage are you getting at the batteries when charging? You can check the charger by removing the end plate where the lights are to see if there is a fuse on the output side of the charger. if there is check to see if the fuse is blown. There probably is a fuse on the other end but since the red light comes on it is good. If you plug the charger into the charger port and put your ear to it you should hear a hum coming from the charger. Hope this helps you
Sep 29, 2010 | Health & Beauty
Charger light does not come on
The red light indicates the batteries are charging and green indicates the charging is complete.
Jun 12, 2010 | Stinger Streamlight 75000
Targus 70watt adapter
Mine was brand new and it worked for 2 days then started doing that. I know it's not my laptop. I work in a computer shop and I tested it several different ways. I think it may be a faulty capacitor. either way, you just have to replace it. That's what I am doing. I would suggest the same.
Feb 27, 2008 | Computers & Internet
Health & Beauty Logo
228 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
