Question about Dell UltraSharp 1907FP 19 inch LCD Monitor
HOW DO I GET RID OF BLUE BOX STATING "MO COMPOSITE SIGNAL AND WHERE IS THE PICTURE IN PICTURE BUTTON
    Genius:
  • Dell Master
  • 1,552 Answers
Your monitor has some of the following inputs:
* VGA
* HDMI
* composite
* component
* coax
You need to "tell" the monitor which of the above "input" channels that the monitor should "listen" to.
Posted on May 13, 2015
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: no composite input signal
Try the following:
Right after power on, tap the F8 key to see if you can get a short menu to come up.
If it does, select "Safe Mode."
If your screen looks different, it may be just the driver for the display card or monitor is trashed (Windows like doing that, keeps us challenged).
- Open Control Panel, then System, then Hardware, finally Device Manager.
- Locate Display adaptors, open and delete the adaptor listed (all, if more than one.)     - Locate Monitors, open, delete any listing there.
Reboot.
Windows should 'find' two 'new' devices and install the drivers for them.
The display may still be different if you had other than the default settings.
Go then to the Display folder of the Control Panel, click on 'Settings' and experiment. Depending on your Windows version, if you choose something dumb so it makes the screen unreadable, ignore it and Win will ask if you want to keep it and give you some time to acknowledge that you like it. When you don't, it will just go back to the pre-tinkering settings.
Posted on Apr 03, 2009
  • 788 Answers
SOURCE: how to remove "no composite inpute signal"
If you have the same problem with both monitors, it sounds like a display card setting or problem.
The chances of you having the same problem with different units is 1- 50.
Try the monitors on a different PC and get back to me.
Posted on Sep 03, 2009
  • 10 Answers
SOURCE: My husband downloaded several Windows
Not sure this will help but it sounds like you might have PIP (picture in Picture ) turned on
Posted on Feb 11, 2011
How to connect Sony FWD-50PX3 to cable box
that depends on the cable box you have.
Your best option is a box with a composite output - that is 5 cables (red, green, blue for video plus red and white for audio) that connect to corresponding 5 holes at the back of the TV.
This is called "Component" signal and is an equivalent in quality to HDMI.
If your box doesn't have that you're stuck with composite cable, which is just 3 cables - yellow for image and same red and white for audio; composite signal does NOT carry high-definition information, though.
It's not the cable that matters, it's the signal carried through it that has the limitation.
Hope this helps.
www.coppelltvrepair.com
Sep 30, 2012 | Sony FWD-50PX3 50 in. Plasma TV
Why is the s video output from my Matrox Mini using y cable into blue and red not giving picture ? Into green and red I get B/W picture only.
sounds like you are trying to drive a composite signal into a YPbPr input.
Look for a yellow video input on the TV and get rid of the splitter, and run the video into that.
Jul 27, 2011 | Televison & Video
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
No picture when hooking component through receiver. Get sound but no picture. Tried to put ps3 in input 1, 2 and 3. Tried multiple cables as well
with Denon you have to go into the menu and "assign" the inputs.
You have to select if you are using HDMI, s-video composite etc.
If your unit has upconverting remember that it will upconvert a s-video signal to HDMI but not the other way around.
HDMI is a digital signal composite, s-video etc are analog therefore you could not use the HDMI output from your PS3 but then use the red, blue green composite outputs from your receiver to run to your tv.
Dec 29, 2009 | Denon Televison & Video
Samsung tv sound but no picture
noavatar_s.gif fastrepairs
Rank: Wiz
Rating: 88%, 28 votes
Make sure your tv is on the right input first of all. The newer flat panel2.gif lcds combine the componenent video (red , blue, green) with the composite video and audio (yellow, red, white). If your tv is on the component input then you hear audio from the composite input since the audio inputs (red, white) are shared. Look for a source or tv input button on your remote or the tv itself and try pressing this button unti you see a picture with sound.
I just used this information to solve the same problem...I ended up disconnecting the cable box and restarting the box until I got to the info panel for the box...the picture magicly appeared with several options. I picked one and problem solved...love the faq's on the search engine. lh in dak
Sep 01, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Screen is blue says composite, no signal.
TRY AND FIND VIDEO BUTTON ON TV REMOTE AND PRESS VIDEO BUTTON. ON THE MENU USE UP OR DOWN ARROW ON REMOTE TO CHANGE FROM COMPOSITE TO ANALOG TV.
Feb 01, 2009 | iLO 3200 32 in. LCD Television
Panasonic Logo Constantly Across Screen
With the Power On, hold down the Play/Repeat On button for 5 seconds. This will toggle the 'feature' on and off.
Nov 06, 2007 | Panasonic PVQ-M2509 Combo
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Dell UltraSharp 1907FP 19 inch LCD Monitor Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
