Question about Hotpoint HSS25GFP Side by Side Refrigerator
Condenser fan making noise and sometimes makes a clicking noise coming from electrical board on back
  • Hotpoint Master
  • 5,323 Answers
Are u sure the noise is from the condenser fan and not the capacitor near compressor? the fan in freezer is making noise usually due to bad impeller or blocked bcuz of ice build up due to defrost problem?
Posted on Apr 17, 2015
watugot
  • 290 Answers
SOURCE: evap fan stops turning
It sounds like the sensor circuit in the motor is out or the motor is binding slightly so that the motherboard can't tell what the fan rpm is. Replace the motor and you should be ok. This is a common failure I have run in to.
Post back if you have any questions.
Thanks/Mike
Posted on Nov 07, 2007
tborn6
  • 700 Answers
SOURCE: Freezer is not keeping food frozen, and is making a clicking sound. The sound seems to be coming from the computer board on the back of the unit.
sound like the starting relay may be bad, get a 3 in one relay and replace the components
Posted on May 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: fridge is not cooling and making a clicking noise
That is a common symptom of a bad circuit board. You need to replace it.
Posted on Oct 03, 2009
Testimonial: "Thank you for the diagnosis. I am going to attempt to replace the circuit board myself, is there anyhting I should be aware of. Thanks, Dave"
  • 358 Answers
SOURCE: Fridge is not cooling and making a clicking noise
Try replacing the compressor relay , which is not expensive , that could be the problem , but if the compressor keeps clicking on and off (overloading) , is probably burnt.
Posted on Oct 16, 2009
Testimonial: "There was a maytag recall of the relay, fortunately they took care of it for free. But, yes relay was the problem."
  • 1891 Answers
SOURCE: The circuit board is making a clicking noise on
replace the main board it ha s failed . there is not repair . just repalce ..mm
Posted on Oct 21, 2010
My GE Profile Refrigerator (model PDS20MBSBB) is making a clicking noise. The thermostat display turns off while this happens. When it comes back on the fridge gets really cold and then slowly gets
needs new control board wr55x10942. condensing fan not running or running slow. it get to hot then the compressor relay cut off compressor to protect it once cooled down enough it starts back running.
Oct 09, 2014 | GE Refrigerators
Refrigerator making squeeling noise once in a while. Noise is like someone complaining in a Charlie Brown cartoon.
. The next time the noise starts , open the freezer door and see if that is where the noises coming from . If yes , replace the circulation fan located in front of the evaporator assembly . If the noise is coming from the bottom of the unit and you can hear it clearly with the doors closed , more than likely it would be the condenser fan located next to and sometimes even mounted on the condenser assembly . If the unit has a static condenser , which will be indicated by the metal lines running up and down and all around the back of the unit itself , there is no condenser fan . The squealing noise you hear is a bad bearing in one of the motors . As the motor shaft spins , it actually wobbles within the bad bearing as too much clearance between the two exists .
Feb 19, 2011 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
The freezer randomly warms up, sometimes up to 24 degrees then will drop back down to zero. It is making a clicking noise but not sure if that's related to the warming-up issue. The food does have frost...
Hi!!
I think the clicking noise behind the unit comes from the compressor bimetal thermal protection, which can be caused by the condenser fan not worikng (the small fan on the back bottom of the unit) and/or dirty/clogged condenser.(the coil in front of the fan)
Also check:
Temp. control knobs,
Small fan in freezer, it should start working after opening the freezer door for a couple of minutes. If it does not start, use a pen or pencil to turn the blades, if it kick in, replace motor.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear.
Once this is done, restart unit
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Refrigerators
It's making a loud running noise
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator make a noise every 3 minutes
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Fridge makes chirping noise
Some areas noise may come from:
Inside:
Whenever the refrigerator is cooling a circulating fan is operating to move air through the freezer and refrigerator. This fan can be found in one of several locations: For freezers positioned on top of the refrigerator the fan can be found on the back wall at the center of the freezer; If your freezer is on the bottom then the fan will be near the top on the back wall of the freezer; and if your freezer is on the side the fan will be on the back about 1/2 way up or near the top.
These fan tend to wear out over time and make a noise like a whistle or chirping sound. Open the freezer and press any switch. If the noise is louder with the door open the motor that operates the evaporator fan is likely the cause. This fan cannot be serviced in any way and must be replaced.
The back of the refrigerator:
The compressor, defrost timer, or the condenser fan motor may be the cause of noise from the back. The compressor is located near the bottom and is identified by it's small black case that appears to have no moving parts, but several colored wires coming out of it. If you find the compressor is what is making the noise then you will have to replace it in order to get the noise to stop, these aren't serviceable (and can be expensive). Near the back of the refrigerator you'll also find the condenser fan. Sometimes this fan gets clogged with debris and can make a lot of noise as a result. If this is the case then simply clean the blade with a soft bristled brush, you can usually get one of these brushes from a hardware store, or you can order it from us by calling our 800 number. If it doesn't need to be cleaned then the whole motor may need to be replaced.
The defrost timer is usually found behind the kick panel. The timer has an electric motor attached to it that may become noisy over time and will need to be replaced in order to get it to be quiet again.
The bottom of the refrigerator:
Sep 21, 2009 | Refrigerators
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
May 31, 2009 | PDS22SFS Stainless Steel
GE side by side Refrigerator makes LOUD SQUEAK when running
Mar 24, 2009 | GE Refrigerators
Clicking
This unit, I believe is a piezo electric cooling/warming unit. It's possible that after or during your defrost, the control board was exposed to excess moisture... whether by condensation (sweating), evaporation or direct contact with the melted water. In this case, if you plugged the unit in before allowing sufficient dry time, it would have shorted your control board. Possibly allow the unit to dry (unplugged) for 24-48 hours and retry. If the same symptom occurs, replace the control board.
Jul 27, 2007 | Max-Fridge STC55926 / STC55927 / STC55928...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
95 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
