Question about Craftsman Garden
I need to know where cables hook up on 6.75 craftsman mrs lawn mower
    Top Expert:
  • Craftsman Master
  • 10,875 Answers
Need complete model number,its on a tag on the mower
Posted on May 20, 2015
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
  • 4 Answers
SOURCE: What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
  1. Lift the tractor / mower seat (pull it up)
  2. You will see there's a small metal label with the serial and model number of the tractor / mower
  3. Check the serial number of the tractor / mower
  4. the first six digits of the number are you the model month day and year (i.e 090999XXXXXXX this tractor was made in September nine in 1999
Hope this helps
Attached is an image of the tractor seat and the metal plate
Posted on Sep 21, 2009
Testimonial: "I did it and there it was, Thanks a lot for the help with the solution for this lawn trctor problem"
The clutch return spring broke on my lawn tractor model 917.272242 and i cannot see at what points it connects my diagram is not a real .can you help
If you go to searsparts.com and put in your model number they will have a diagram as to how the spring attaches.
Jun 20, 2014 | Craftsman Lawn Mower
I need to know how to replace clutch cable
Hi You have to look under the tractor and look at the linkages. Press the pedal and watch what moves and where it goes to. You may have to pull off a back wheel. If you have a new one already it will give you a better Idea on how it hooks up. Usually you should just have to look at the original setup to figure it out.
May 30, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Can't remember how to charge battery in craftsman 675 lawn mower
first hook up positive side of charger then negative side of charger make sure you do this in open air so battery gas can excape while charging
Sep 26, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
Craftsman MRS 650 Series (Self Propelled) After priming the mower runs for 40 seconds but not at full power, then suddenly stops.
sounds like the jet is slightly clogged,
Take the carburetor bowl down and clean holes in jet with small wire (SEARCH : acetylene torch tip cleaner)
Aug 27, 2013 | Garden
I need to charge the battery
check under the seat and possibly under another plastic cover
May 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower only picks up when being pulled backward
if you have had the mowing blade replaced it could be upside down
Jun 05, 2009 | Garden
How do I change the oil in a Sears Craftsman MRS 650 self propelled lawn mower.
Tip the mower up on it's side with the dip stick tube on the lower side and dump the oil out. Best to run the mower till its out of gas first.
Apr 23, 2009 | Garden
How do you remove the mower deck from a craftsman riding lawn mower
Most of these have a cable to pull deck into gear, which has a r clip to remove ,than two rods that go from font of deck towards front axle- remove 2 R clips to drop them, and 2 more at the back of deck, un hook belt around engine pulley, than slide deck out. See how this goes. Or you my have dune it by now.
Dec 15, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
50 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
