Question about Refrigerators
I need an icemaker. Do I have to buy the entire assembly?
    Sergeant:
    Champion:
  • 253 Answers
If you already have an ice maker, then just go online and buy a replacement. If not then you'll have to buy the whole unit. Most refrigerators are already ice maker ready, you just need the unit.
Posted on Apr 12, 2015
I have a GE Adora side-by-side refrigerator Model # DSD26DHWA-BG. About 1 year ago the ice maker stopped producing ice. The mold that forms the ice cubes is filling up with water but never pushes out...
Hello, there are three screws that hold the icemaker in place if you remove these three screws and unplug the icemaker and remove it from the unit. After you take the icemaker out take the entire unit with the cover on it and run it under hot hot water this is actually quiet common for an icemaker to freeze up well actually its the parts on the inside of the icemaker that are freezeing up. After you defrost the icemaker as I term it then you would dry the icemaker and reinstall it. when the icemaker reaches 32 degrees the icemaker will call for water once again from the water valve if at this time after the ice forms the unit still doesnt drop the icecubes then you would have no other alternative then to buy another icemaker they usually sell for around 50-90 dollars american. The icemaker is not worth replacing parts on due to if you were to replace parts on the icemaker you would end up spending about 4 times as much as the entire icemaker costs. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again Rick
Jun 04, 2011 | GE Refrigerators
Icemaker rakes not moving, though it is in the cycle and making a lound humm, grinding type sound (similar to when it does its normal ice rake cycle.
Normally, icemakers make very little noise. If it is in the middle of a harvest cycle and will not complete the cycle, remove the icemaker and look to see if an object some how fell into the ice cube mold area, preventing the rake from turning. If there is no obstuction, you will have to buy a replacement icemaker, as there are no replacement parts available. NOTE: Do not leave the icemaker in your freezer in the middle of a cycle for extended periods, as the mold heater would be "on" and adding heat to your freezer section the entire time, causing your refrigerator to work harder than normal, and costing more to run.
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
MY REFRIGERATOR WATER DISPENSER IS NOT WORKING ONLY THE ICEMAKER IS?
You could have an issue with one of the following:
* water valve assembly's water dispenser solenoid (located in the lower rear of the refrigerator). If this is the problem, you must replace the entire water valve assembly.
* water dispenser actuator switch/button
Contact an appliance service company.
Feb 16, 2010 | Amana AFD2535DES French Door Refrigerator
Kenmore 52552100 refrigerator not working
Hello.... do you still have the parts??
I can use Part 921526 PC Board kit, emitter & reciever icemaker - $30.
You can email me at durangoboy@xemaps.com
Thanks,
Paul
Oct 09, 2009 | Refrigerators
My ge profile ice machine on off light is blinking and not making
Blinking light indicates a fault with the icemaker. Look for a blockage preventing the ejector from making a complete revolution, such as a cube that was not cleared, or some other mechanical blockage. All other faults are icemaker component, which are not available as separate repair parts, which would require replacement of the entire icemaker assembly. Please don't rate this if you need a new icemaker, as anything less than a Fix-Ya lowers my score. Thanks.
Jan 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice tray overflow
Sorry for taking so long to answer.  The icemaker needs to be removed from it's mount to install the updated tray.  There should be only one screw on the front of the bracket supporting the icemaker.  Once the screw is removed, slide the entire icemaker assembly forward and drop it down.  This will expose the wire harness connection.  Disconnect the plug from the connector and take the icemaker out to work on it.  You need to remove the motor part of the icemaker from the bracket to replace the tray.  Carefully push the bracket up as you push the motor box down and slide foward to separate the two.  It looks impossible but it actually does come apart easily.  Once the box is separated, the tray can be replaced.  Reverse the process to assemble.  Good luck.
Sep 23, 2008 | LG LRSPC26930 Side by Side Refrigerator
U-Line 95
The part number is #150 faceplate. This would be the motor and switches. Approx $55.00 Appliance parts depot would have it. Or try all brand parts.
Jun 07, 2008 | U-Line Icemaker
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
