Question about Dishwashers
How to fix a bosh dishwasher with E 01 code - Dishwashers
  • 5,384 Answers
The E01 error may mean that the water flow into the washer is restricted or that the flow meter is not reading correctly. Sometimes the control board near the washer inlet is faulty and can't read the signal from the flow meter or send that message to the control panel.
First check your shut-off for the dishwasher and make sure that it is open. Next turn the valve off and disconnect the inlet hose. Connect a new hose to the valve and position a bucket under the hose. Open the valve and check the water flow. If you have good water flow, try connecting this new hose to the inlet of the dishwasher. (Unplug the dishwasher. For an under-cabinet dishwasher, you'll need to pull the washer out. Make sure to keep the discharge hose from pulling loose. Then disconnect the old hose from the fitting and connect the new hose instead. Then slide the washer carefully back into place without pinching the hoses or cables.)
If you add a comment with the model number, I may be able to give more specific directions and replacement part information. Of course, if the dishwasher is under warranty, contact Bosch.
I hope this helps.
Posted on Apr 12, 2015
What is E22 error message on Bosch dishwasher
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS..
Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Bosch Dishwasher Error Codes How To Clear What To Check
Apr 24, 2016 | Bosch Dishwashers
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Error code 01 after problem has been fixed on electrolux dishwasher
Good Morning Friend,
I understand you are receiving an error code "01" on your Electrolux dishwasher, even after the problem was fixed. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Electrolux Dishwashers
More than one error code 01 on electrolux dishwasher
I understand you are receiving more than one, error code "01" on your Electrolux dishwasher. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosh shu43c never stops running.
If you have a Bosch shu4300...check this site.
http://fixitnow.com/wp/2006/06/09/bosch-dishwasher-takes-forever-to-complete-a-cycle/
My issue was a heater fault and fixed the problem by resoldering a bad joint. Works fine once this was fixed.
Nov 24, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
321 people viewed this question
Top Dishwashers Experts
