Question about Micro-Star/MSI MSI A6200-461US Notebook PC - Intel Core i3-370M 2.4 GHz Processor -
How do i manually turn on bluetooth
I have tried the 'shortcut' way by hitting the 'FN' button and then the F9 button but it does not work.
  • Micro-Star/MSI Master
  • 3,320 Answers
It is doubtful that there was a bluetooth chip installed in this notebook given its age.
Buy a USB Bluetooth dongle.
You can check your computer by going to control panel, system, system info and look at the hardware installed. 6results for msi a6200 461us USB Bluetooth v4 0 USB Dongle Monoprice com
Posted on Apr 12, 2015
Mouse touch pad not working
'F9' keys has a mouse, no mouse looking symbol. sometimes you use the 'Fn' key in conjunction with 'F9' key, sometimes not. Give it a try by itself and use it. If not hold the Fn key and hit F9 and try again.
Jan 08, 2014 | Toshiba Satellite A355-S6925 Notebook
Monitor to bright
Decreasing Screen Brightness (FN+F9)
Press and hold the FN key, then hit the F9 key to decrease screen brightness.
Increasing Screen Brightness (FN+F10)
Press and hold the FN key, then hit the F10 key to increase screen brightness.
Mar 21, 2012 | HP Compaq nc6230 Notebook
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
HOW THE FN+F1,F2,F3,F4,F5,F6,F7,F8,F9,F10,F11&F12 WORKS???????
FN+ F buttons are used as a shortcut. For example, in my laptop, F1 button has a ? icone at the bottom. when a pres Fn+F1, it will launch the help program. F1 to F12 buttons have different shortcuts.
Apr 29, 2011 | HEWLETT-PACKARD Hp G62-225dx Laptop...
How do I adjust the screen brightness?
Press and hold fn button on your keyboard, then press F7 to decrease brightness and F8 to increase brightness. That is Fn + F7 or F8.
If F7 or F8 doesn't work try F6 or F9.
Or you can just start from F1 to F9. One of these buttons certainly would work.
Regards.
Apr 19, 2011 | Compaq Presario Notebook
How can I disable the trackpad to only use an external mouse? Toshiba laptop (Satellite)
For most Toshiba laptops, you should be able to hit FN+F9, and it will disable the touch pad. If that doesn't work, go to your Control Panel, Hardware and Sound, Mouse, and disable it there. Hope this helps!
Mar 28, 2011 | Toshiba Satellite 2400-S251 Notebook
My hcl me laptop problem is that bluetooth n web cam is not working
I am sure this is not relevant to you anymore but for other visitors of this page. In HCL ME laptops Wireless Internet, Bluetooth and Webcam does not gets automatically start when you start your laptop. So before doing any re-installation of drivers check the shortcut keys for those. For me: Fn + F9 = WiFi, Fn + F10 = Bluetooth and Fn + F11 = WebCam.
Jan 26, 2011 | Cameras
Fn toggles (fn/f9 and fn/f10) don't work
the fn screen brighter/dimmer toggles (fn/f9 and fn/f10) don't work
Dec 16, 2009 | HP Configurable - HP EliteBook 2530p...
How do you unlock the mouse touch pad?
5. Go to http://support.toshiba.com there click on Downloads.. select your computer.. Product=Portable, Family=Satellite, Model=M35X-S149.. then click on "GO" button on the right.. Again in the next page that comes up click on "Downloads"..
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else.
Thanks for using fixya...
Sep 15, 2009 | HP Compaq nc6000 Notebook
My mouse button is lock how do i unlock it
5.Install Drivers
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
Jun 25, 2009 | Computers & Internet
Micro-Star/MSI MSI A6200-461US Notebook PC - Intel Core i3-370M 2.4 GHz Processor - Logo
167 people viewed this question
Top Micro-Star/MSI Computers & Internet Experts
David Payne
David Payne
Are you a Micro-Star/MSI Computer and Internet Expert? Answer questions, earn points and help others
