Question about Pool & Spa
Air pump not working and red light stays on reset. Is the pump bad or electrical problem?
Pump won t fine when I put it away in the fall. When I plugged it in the red light stays on the reset. I think it was green before. The pump will not work. Also show e 90 as error code. The spa is less than one year old
  • 1,631 Answers
It is a toy spa after all, not really meant to last long.
According to Intex, your fault code is due to low or no water flow. Most common problem that we see is bad filter. You either need to clean, soak, or just replace them! Because they are so small, I wouldn't even bother with cleaning them, just have a few handy, and just install new ones.
Posted on Apr 13, 2015
True air heat tries to start then goes to gas.It worked fine in the fall but it is now -5F
Do you have a heat pump and gas furnace setup? Or is it electric and gas setup.
To me it sounds like either configuration issue its electric and gas, but if its heat pump/gas the furnace is defaulting to gas more then likely on the outside air temperature, usually most heat pumps only heat good down to 10 degrees F.
Nov 18, 2013 | Coleman Heating & Cooling
My 2000 Ford Expedition 5.4L V8 4x4 idles really bad when stopped at a red light. Sometimes it will just stall. It always starts back up. It goes just fine when I hit the gas, real smooth and powerful. It...
Check the idle fuel pressure. Load the electrical with headlights and heater defrost etc and see if problem gets worse. Attempt again with all accessories off. Could be fuel pump is getting low voltage at idle or fuel pump is failing. Bad fuel pump would definitely be a problem high fuel demand. Check vacuum line between pressure regulator to intake manifold.
Check for a air leak in the intake manifold. Gasket/hose etc. The P0171/P0174 is an indication that not enough fuel or tow much air. You can sometimes hear the air leak during idle.
Best solution is to use a graphic capable scan tool and watch the fueling trim/idle.
Mar 04, 2017 | 2000 Ford Expedition
01 ford explorer sport won't stay running. turns over fine and starts but quits right away
Check for vacuum leak at intake manifold or bad fuel pump relay or have fuel pressure checked to see if fuel pump is working properly 40-45 psi it should be pumping
Dec 18, 2011 | 2001 Ford Explorer Sport
Help me with my 1993 chevy cavalier 2.2L engine. My car won't turn on when ignition switch is in the on position. When I turn it to the on position, my radio cuts on, and my air conditioner turns on,...
what do you mean by "dash lights"? how do you KNOW the pump isnt working? how do you KNOW its good? at the ignition switch the ORANGE and PINK should have power in the RUN position the BROWN and TAN/WHITE should also be HOT in the run position. There should be a red wire near the fuel pump relay, make sure its HOT when cranking. IF its HOT and the fuel pump doenst run, the pump is bad. You can also put 12V on that red wire and power the pump.
Aug 26, 2011 | 1993 Chevrolet Cavalier
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
I have a 1987 chevy s-10 blazer v6 2.8 fuel injected dat starts up but dies out?
sounds like the fuel pump is not staying on or the ingtion switch doesn't make in the run position ( happens alot to vehicals take have lots of keys hang on the switch) The sparp going away is easy to check with a test light theres a connector on the distrubutor that has a heavy red wire plugged in that goes to the B+ terminal it should be hot with the key in the run position. if it's dead fix the connection at the ingtion switch ( it's on top of the steering collum and all but one wire will be hot with the key on, that one comes hot in start) if it's good the fuel pump is next it has a fuse on the passenger side firewall next to the fuel pump relay. Fuse bad or relay bad or dirty it'll act this way. The start wire entergizes the pump in crank position. then the oil pressure switch takes over and keeps the pump on. theres 3 wires on the oil pressure switch the center wire works the light the left one is fuel pump fuse power and the right one is the fuel pump. the oil switch can go bad and the connection can go bad the wire can fall off or get broken. the wire to the fuel pump may not get all the way to the pump.. You can add power to any wire on the swich with out hurting anything. all of the wires will be hot with it plugged in and running. unplugged two wires are hot with the key on ones the light ( oil Pressure light) the other is the key on power for the pump with oil pressure the switch closes and the pump comes on and it'll be powered right off the starter as it's cranking. If the switch is leaking oil its likly failed too.
Oct 01, 2010 | 1987 Chevrolet Blazer
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Thermostat?
It actually sounds to me like you're low on coolant. My Jeep leaks coolant and whenever it gets low the temp gauge will go real high and then drop, and the heater doesn't work well. This is because the cooling system of your car is supposed to be a closed system, full of coolant and no air. When coolant leaks out, the space it used to occupy is now occupied by air, which does not transfer heat well. When 'air' is passing through your cooling system, no heat can be transferred from your engine to the heater and radiator, resulting in a hot engine and no heat at the heater. Then when a pocket of water passes through the system, the temperature gauge quickly falls as the water absorbs the heat from the engine. The hot water that cools the engine is where the heater gets it's heat from as well, so when water passes through the heater core, the heater works, but when it's filled with air, it doesn't.
Hot water runs through the heater core regardless of whether or not your thermostat is open or closed. That's why your heater works in the winter even before the engine is at normal operating temperature. The fact that the heater stops working is a good sign that the thermostat is probably not the culprit.
As for the water pump. If the water pump was bad, your temp gauge would go into the red and stay there. Water pumps generally don't work intermittently. Either it's good and ot works, or it's bad and it doesn't.
However, if you are in fact low on water, as I suspect, it means you probably have a leak somewhere. The leak could be in the water pump housing gasket, so depending on where you take it for repairs, they may try to sell you a new water pump anyhow. So just beware of that.
Feb 12, 2009 | 2004 Chevrolet Blazer
BMW 328I No Heat ..Cold air only
water pump may be the way to test take off cap when cald hold reves see if water flys out if so ok if not water pump maybe on the way out
Jan 16, 2009 | 1999 BMW 328 Series
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Pool & Spa Logo
172 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
