Question about Proscan 32LB30QD 32 in. LCD TV
Have 3 segmented blocks on TV screen, is this a problem with the tube?
Three different colored segment's showing on the screen. Is this a problem with the bulb going out?
    Novelist:
  • 167 Answers
Need a little more info,if it is a rear projection then I would have to have it in the shop. Several things can cause this with the three tubes. If not a rear projection then the problem is in the main board. Not much help but it is hard to do voltage checks without the set.
Col. Dana Gillespie
Posted on Apr 13, 2015
  • Col Dana Gillespie
    Col Dana Gillespie Apr 14, 2015
    I wouldstart with replacing the main board. It sounds like it is faulty and trying to put a picture in on multiple inputs i.e. video 1 - video2- uhf - vhf etc all at once
It not bringing out color.it showing black and white
HI,
I will need some clarification as to the model number of your projector to best help you but in general if you have a DLP type projector & suddenly lose all color to your image then the color wheel has failed by burning out or breaking. The color wheel sits directly in front of the projection lamp & if you take your lamp out you can use a flashlight & point it in towards the spot where the light comes out of the lamp & look at the color wheel. The color wheel has 4 to 6 different color pieces called segments like yellow, red, blue & a clear segment. You will be able to see if the color wheel is broken.
If it is you need to have the unit serviced. If you're handy you may be able to order a new color wheel. They are usually around $100. There can be other causes as well but the wheel is the first place to investigate. Please let me know if this was helpful.
Thanks & good luck,
Jim
Apr 14, 2011 | Acer Office Equipment & Supplies
How do I set my Hager timer EH711 to on at 7pm and off at 7am
Resourceful do-it-yourselfer will find following information helpful for solving problem.
Max Load 1000Watts incandescent
http://waterheatertimer.org/How-to-program-Hagar-timer.html#700-series
Manual uses several languages including English
http://waterheatertimer.org/pdf/Hager-EH711-Timer.pdf
Hagar 700 series analog timer has mechanical dial that rotates as time passes.
Segments located on outer edge of dial are moved down-and-out, or up-and-inward to set on-off times.
As dial rotates, segments move lever that turns Load on-off.
With segment timers, all consecutive segments between on and off times have to be pushed in place.
Since EH700 series timer has NO NC terminals, segment position is determined by how timer was wired.
This is because segments-in and segments-out turn different terminals ON.
As a result, the best way to set this timer is to push 10 consecutive segments down-and-out.
Leave rest of segments up-and-inward.
Then manually rotate timer dial to watch when Load turns on-off.
Hagar analog timers also have a switch located in bottom right.
This is the manual override switch.
Set switch in position "I" and then rotate timer dial to watch when Load turns of-off.
Set switch in position "O" and then rotate timer dial again to watch when Load turns of-off.
Manually rotating dial and experimenting with segments and switch will tell resourceful do-it-yourselfer exactly how to set timer.
Once segments and switch are set, then rotate timer hands until current time shows on analog dial face.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 17, 2011 | Hardware & Accessories
How do i pull the segment pins up on a woods 1702 timer for the off time
Following link shows types of segments and pins:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
The Woods 1702 outdoor timer has segments that are 'similar' to the second photo from left.
I test these timers, and the segments and pins are small.
Segments can be pried up using fingernail file.
Sometimes the segments also pull outward and not straight up.
Each timer is a bit different.
Dec 21, 2010 | Hardware & Accessories
How can I tell if I have pressed "down" to turn lamp on? I don't see a difference.
Are you talking about raising and lowering the segments?
See images of timer segments and pins.
If your timer style is not show, add a comment.
You posted under Woods 59200 timer.
There are segments located around edge of dial.
Each segment represents 1 hour
Timer arrives with segments pushed down.
To set timer, raise the segments up for all times you want timer OFF
Leave segments down for times you want the timer ON.
Dec 14, 2010 | Woods 59200 Lamp and Appliance Timer with...
We hope you have an answer and solution to our problem. Our Bravia is nearly three years old. Was working well until a few weeks ago. The screen gets divided into four horizontal segments from right to...
Hi Andrew,
The failure with your LCD is with a defective T-Con also called LCD controller board but is some cases it could also be a defective screen. The cheaper way for the time being would be to replace the T-Con board and hopefully that should fix it. If after replacing the T-Con board the LCD still fails then the screen is way to expensive to replace, the cost of a new screen would cost the same as buiyng another LCD or more.
Check this link to find the T-con board.
This board is located in the upper middle part of the LCD cover with a metal shield.
Let me know if you need further assistance.
Jul 30, 2010 | Sony BRAVIA KDL-46V3000 Television
New Color Wheel not the same as original part which is 7 segment
you got sent the wrong color wheel, You will definatly need a 7 segment whhel for your model.Your color index will be off with the 6 segment wheel and you wont be able to index it correctly
Apr 02, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Toshiba SD-K740
Just try the skip button, it will skip u from chapter to chapter if the DVD has the feature, I donno about segment skippin....never heard of that one.
Sep 01, 2008 | Toshiba SD-K760 DVD Player
Showing picture in three segments
Test through MENU? explan that please. are there different colors that lead you to idea that is convergence.
Jan 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
3D Extrude and Bevel in Illustrator CS 3
Chances are you have chosen 'stroke' color as 'blank/empty' in the first pie chart, and 'stroke' color as 'black' in subsequent charts, by mistake. So as a result the charts are having a black outline. You simply have to select 'stroke' or 'outline' color as blank as you did in the first chart. Colors can be chosen in the 'swatches' palette, either for 'fill' or 'stroke' or both. Hope this solves the problem.
Dec 19, 2007 | Adobe Illustrator CS V11.0 for PC
Proscan 32LB30QD 32 in. LCD TV Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
