Question about Kidz Motorz Police Motorcycle Ride-On in White
How do you repair the kidz motorz police motorcycle i have changed the battery and fuses it only runs for about 20 minutes then stops
  • dal mac Apr 05, 2017
    have you got your answer ? could be time for new battery ? send some pictures of battery and there wires . abodyman78@hotmail.com
10962j police watch despite battery change my watch works spontaneously minute hand keeps stopping?
Seems you are not alone encountering this fault. back to the service centre of into the bin I fear.
Aug 18, 2014 | Police Navy-X PL-10962JSUB/02 Watch
1995 VF750. The bike will start after i take off of the trickle charger. Idled for about 20 min then died and won't start. Put back on the trickle for a couple minutes and it started again. I think the...
It has either a generator or alternator style system. So ya your killing the battery and need to stop that till you fix the generator charging system. Check the fuses and wires for any breaks. May need a new stator or charging controller if the fuses are not the problem. May be even a bad ground wire.
Jan 02, 2018 | 1995 Honda VF 750 C Magna
I have a police watch 10973J and one side of the time piece has stopped working but the other side is still going - do they run on seperate batteries ?
yes they have separate batteries because it has two module. the battery of the side that stop had to be change. i hope i had been helped you.
Aug 12, 2011 | Police Twingear Watch
I needed to jump start my 09 ninja 650r. I turned on my car connected the cables and touched them to my bike, I heard a spark or click sound and then nothing happened. When I turn the key to the on...
Sorry, no reset.
check all fuse links and fuses, hopefully those went before your chip.
When jumping a bike, connect bike first and disconnect first.
Jun 10, 2011 | 2009 kawasaki Ninja 650R
My 2000 Ultra Classic when riding the power goes completely out, engine and all. The run is about 20 to 30 minutes when everything stops. This doesn not happen on all runs. I wait about 2 minutes and...
When you're saying "everything stops", do you mean everything electrical stops? If that's the case and it restarts in about two minutes, it sounds like something is tripping your main circuit breaker. I do not have a schematic for your bike but it has to be something that is not protected by the smaller fuses. If it were, the fuse would blow before the main tripped out. The main circuit breaker should be located right there with your other fuses. It'll be a metal can like device about a half inch wide, a half inch tall, and about an inch long. It should be 30-40 amps rated. Whatever the rating is, do not change it as it's designed to protect your wiring harness. It may have just gotten weak and needs to be replaced but this is rare. Have you added anything electrical lately? This could be just enough to "trip it over the edge".
Good Luck
Steve
Aug 09, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Engine dies after 20 minutes of running.
try some Berrymans B12 fuel additive in the tank. if your bike has been in storage it could be gummed up a bit. put in a little more than stated dose, no more than double, run it let it get hot and then let it stand overnight. it worked for me on my v star
Mar 30, 2009 | 2003 Yamaha Road Star Warrior
Kidz Motorz Police Motorcycle Ride-On in White Logo
790 people viewed this question
Top Kidz Motorz Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Kidz Motorz Toy Expert? Answer questions, earn points and help others
