Question about John Deere Garden
I have a Z425 John Deere will not kick on blades PTO
  • John Deere Master
  • 1,169 Answers
Check the electric PTO clutch coil resistance should be around 1.7 to 2.5 Ohms. If not within this then it is bad. If okay work your way back to the PTO switch and ignition switch checking for voltage as you go. Where the voltage drops out is probably the source of the problem.
Posted on Apr 13, 2015
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
How to replace coil pack on John Deere Z425
Concerning a Z425 John Deere mower. When I start the mower it shuts off immediately, when I try it again the motor cranks but will not start. any suggestions?
Sep 06, 2012 | John Deere Garden
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
I have a cub cadet 2166. Blades are not kicking on when the pto switch is engaged
hello, the pto or belt is bad,for the pto repair see u tube,,
Feb 18, 2012 | John Deere Garden
John Deere JS 40 kick back when pulling rope and does not start
hi there
trucks606
sounds like you may have sheared the flywheel timming key ?
but 1st check for loose blade or broken blade adapter or pto key (pto key is inside the adapter )
then remove starter cover and tank check flywheel key most likly sheared symptoms fit
take look
cheers pauly46
hope it helps
dont forget the thumbs rating
Jun 06, 2011 | John Deere Garden
Pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Sep 18, 2009 | Garden
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
Garden Logo
148 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
