Question about Tablets & eReaders
My tablets charging connection has slipped farther into tablet, how do I fix this?
  • Tablets & eR... Master
  • 3,320 Answers
The USB connector is a weak link in tablet construction. Usually it is just held in place by the solder although sometimes there is a bit of glue dabbed on it for strain relief. Most low cost tablets are not worth being repaired by a technician, so if the connector is still working, you could try to pull it out to the proper alignment and squirt a little crazy glue in to hold it in place. If the connector is not working, toss it in the recycler and buy a new one. And buy the extended warranty.
Posted on Apr 13, 2015
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
How do I fix my tablet that won't fully charge?
Your tablet may need its battery calibrating. To do this run your tablet until it turns itself off, this will ensure that there is no charge left in the battery. Then leave it on charge until the battery is full. Normal battery use on modern devices like tablets and phones should be between 25-75%, with a calibration once every 3-6 months to ensure a good battery lifespan. If this solution does not work you may need to replace the battery.
Jul 07, 2014 | Visual Land Connect 9" Android Tablet...
How do i fix uncharging asus tablet
1st) Check that cable is working with computer connected to tablet. When connected to a computer does the computer see the tablet?
2nd) Check to see that the charging block providing power. If not try placing it in a Ziploc bag and placing it in the freezer for about 20 minutes. They contain a thermal circuit breaker.
3rd) If it is charging and wont turn on. Hold the tablet vertically, connector facing down and lightly tap it on a hard surface, unplugged of course. Reconnect charger.
May 02, 2014 | ASUS Tablets & eReaders
Power Problem
I have the matsunichi 9.7 my email has amessage saying connection problem no emails has come in for 2 days. What can i do to fix the problem
Mar 05, 2014 | Matsunichi Marquis Mp977 Marquispad 9.7"...
My zeepad tablet won't work anymore. it won't turn on! it also won't charge! What can I do to fix it???
cant connect to google i got a gmail still wont let me connect my wifi works on it thats the only place i cant go
Dec 21, 2013 | ZEEPAD Tablets & eReaders
The hole in the tablet to connect the charger is broken I can not charge the tablet. What to do?
take a razor blade and open the cover.Carefully resolder the connection back in place. use flux and very very little solder. fixed mine :-)
Aug 14, 2013 | Coby Kyros 716829701508 Tablet PC
Usb slipped into tablet and now can not connect to keypad or charge it
take it to a repair man i believe if u take it apart yourself you lose your warrenty most electronics havea seal on the inside so they can tell if you messed with it
Jan 04, 2013 | Tablets & eReaders
No power
I had the same problem! It's not your charger, it's the tablet.
Most likely, the soddering came apart on the inside of the tablet, on the part that connects the charging port with some important wires. You can either take the cover off and fix it, but if it's like mine, it'll just come apart again.
This is what i did: plug in the tablet, and cross the cord from the right across the screen, to the left, and make sure it's tight. I use a binder clip to make sure it stays and charges.
Now try powering it up....that should work :)
Dec 08, 2012 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
48 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
