Question about Thule 2003 Chevy S10 Pickup - Extended cab - Xsporter Truck Rack
No spark from coil - Thule 2003 Chevy S10 Pickup - Extended cab - Xsporter Truck Rack
What is a coil pack on a car
A coil pack is the modern-day equivalent to an older vehicle's ignition coil (which provides electrical spark for all of the spark plug wires when combined with a distributor, distributor cap and rotor). However, one coil pack usually only drives 2-4 spark plug wires or boots (though some drive 6). In some cases 1 coil-on boot configuration is used and no spark plug wires are present. In this case the vehicle may use one coil per spark plug. Basically, a modern V8 will require 2-8 coil packs to provide spark for combustion, where'as an older V8 would usually only have one ignition coil. A four-cylinder vehicle will usually have 2-4 (depending on whether or not it utilizes a coil on boot configuration). Some V6 vehicles use 1 coil pack for all 6 cylinders and the top resembles that of an older distributor cap, with connections for spark plug wires. Many V6 configurations use 3 coil packs. Coil packs should be replaced every 60,000-100,000 miles with a full tune-up, or as need. They are expensive, but they help your vehicle operate efficiently and are good for the environment.
Sep 01, 2014 | Vehicle Parts & Accessories
No spark on Huskvarna Rancher 55
disconnect any and all kill wires going to the coil... if you still have no spark then it can ONLY be the coil... if this produces spark then you have a kill system problem or your flywheel has no magnetism... and this can be the only solution as you do not have points/condenser or things just went full derp
Aug 27, 2014 | Garden
Cant find plugs on a 3.7 6 cylinder 2 wheel drive dakota please help
3.7L Engines
Each individual spark plug is located under each ignition coil. Each individual ignition coil must be removed to gain access to each spark plug. Refer to Ignition Coil Removal/Installation. Prior to removing spark plug, spray compressed air around base of ignition coil at cylinder head. This will help prevent foreign material from entering combustion chamber.
  1. Remove spark plug from cylinder head using a quality socket with a rubber or foam insert.
  2. Inspect spark plug condition.
To install:
  1. Start the spark plug into the cylinder head by hand to avoid cross threading.
  2. Before installing coil(s), check condition of coil o-ring and replace as necessary. To aid in coil installation, apply silicone to coil o-ring.
  3. Tighten spark plugs to 27 Nm (20 ft. lbs.) torque.
  4. Install ignition coil(s). Refer to Ignition Coil Removal/Installation.
Sep 21, 2013 | Cars & Trucks
I got code PO 305 on a 2002 Mercury Grand Marquis, what is the spark plug wire part called, is it #5 coil, and should I replace the coil and spark plug and what should the spark plug be gapped at? Thank...
This will have a direct coil over ignition with a coil over each spark plug. The coil is the electrical part over the spark plug. The coil also has a rubber part that is called the boot or spark plug boot. The boots can be purchased separately but the coils will come with new boots.
is it #5 coil,
Have you checked to see if there is any spark coming out of the number 5 coil?
When was the last time the spark plugs where changed? It may be due for all the spark plugs to be changed. The spark plug gap is usually listed on the emissions sticker under the hood. It should be .050 - .056 or very close to that.
May 16, 2011 | 2002 Mercury Grand Marquis
Where are the spark plugs on a 2005 galant 2.4
REMOVE TOP ENGINE COVER,REMOVE CYLNDER HEAD CENTER COVER,YOUR WILL SEE IGNITION COILS SETS ON TOP OF SPARK PLUGS.ALL 4 SPARK PLUGS EACH, WILL HAVE A IGNITION COIL ON TOP OF THEM.REMOVE THE COIL SCREW THEN UNPLUG THE COIL ELECTRICAL CONNECTOR.REMOVE COIL, THEN YOU CAN REMOVE SPARK PLUG.YOU WILL NEED A LONG EXTENSION AND A LONG SPARK PLUG SOCKET TO REMOVE SPARK PLUG.
Apr 08, 2011 | 2005 Mitsubishi Galant
How do you replace the spark plugs on a 1998 2.7 Intrepid?
REMOVAL
Always remove the ignition coil assembly by grasping at the spark plug boot, turning the assembly 1/2 turn and pulling straight back in a steady motion.
  • Prior to removing the spark plug, spray compressed air around the coil area and spark plug.
  • Remove electrical connector from ignition coil.
On 3.5L engines, it is necessary to loosen the screws by alternating back and forth. Do not lose the spacers under the coil when loosening the screws.
  • Remove 2 fasteners from ignition coil.
  • Remove ignition coil assembly.
  • Remove the spark plug using a quality socket with a rubber or foam insert.
  • Inspect the spark plug condition.
INSTALLATION
  • To avoid cross threading, start the spark plug into the cylinder head by hand.
  • 3.5L engines tighten spark plugs to 28 N·m (20 ft. lbs.) torque, 2.7L engine tighten spark plugs to 17.6 N·m (13 ft. lbs.).
  • Install ignition coil assembly onto spark plug.
  • Install coil screws and tighten: 2.7L engine to 6.2 N·m (55 in. lbs.), 3.5L engines to 6.7 N·m (60 in. lbs.).
  • Connect the electrical connector.
Aug 27, 2010 | 1996 Dodge Intrepid
How to replace 1997 buick inition coil
I just did one the other day. There are three coils. You can determine which one is bad by using the number one spark plug wire and an old spark plug. Put the spark plug in the wire ( while it is still in the coil) and ground the plug against the engine block. Make sure it is grounded solidly to metal or you could get a nasty shock. Have someone start the engine. Look at the spark. It should be fat and blue. Turn the engine off as soon as you have seen the quality of the spark. Pull one of the wires from each coil in sequence and move the number one wire to that coil. Proceed as above. The weak coil(s) will have intermittent spark, yellow spark or maybe none at all. Once you know which coil(s) are bad remove the two small screws at the ends of the coil. They hold the coil down. Pick the coil straight up, pulling the contacts out of the ignition module. Set the new coil in place and screw it down. Both towers spark every time the coil fires so reinstall the wires in either spot on a given coil. Good Luck
Apr 27, 2010 | 1997 Buick Park Avenue
No spark to the coil
No spark to the coil or is it no spark from the coil? First verify that you have 12 volts to the coil when you turn ignition switch on if not you will never have spark from the coil going to the plugs. If you do have 12 volts to the coil and still no spark you have a bad coil. To see if the coil is firing, unplug a spark plug wire from it's plug and hold it to a chasis ground while attempting to start the vehicle. There should be a strong spark and popping sound. Remember to wear leather glove or thick work glove if holding the wire by hand to avoid shock. If there is a strong spark then coil is good.
Sep 25, 2009 | 1997 Chevrolet Express
How do i plug in the spark plug coils? what order?
If it's the four cyl., the first coil pack bolts over the #2 spark plug. The #2 coil pack wire plugs into #3 spark plug. The number two coil pack bolts directly over the number four spark plug, and the #2 coil pack wire plugs into the #4 plug. The firing order is 1-4-2-3.
Jun 30, 2009 | 2000 Mazda Protege
1990 Subaru Legacy shorted out the ignition coil. I replaced it and in less than 1 mile,it shorted out the new one.
Subaru engines (including Legacy and engines of many other automobiles, GM, etc.) have returned to so-called wasted spark ignition systems since advent of the electronic distributor-less ignition (having been used historically in early engines with magneto ignitions). With this approach, the ignition systems are less expensive and usually quite reliable. At the same time, however, a shorted spark plug (cracked or carbon clogged, etc.) (or bad ignition spark plug wire) grounds both the ignition spark and the false spark being used. This means that it also grounds the corresponding respective ignition spark of the other 180 degree out of phase cylinder (that uses the same the same coil because the spark current is connected to the spark plugs of two cylinders). Since such a defect allows more current to flow in the spark coil to two plugs when the resistance of the spark plug gap disappears due to a cracked plug, etc, it seems likely to hasten coil burn out if the spark plug/plug wire defect is not corrected before installing the new spark coil.
To explain further, wasted spark means that when a cylinder is ready to fire, it gets a spark to its spark plug while part of the spark (from the same coil and current) as a sort of copy is also sent to another cyclinder at the same time but when the piston in that cylinder is exhausting its ignited gases 180 degrees out of phase from when its spark is needed. When the second cylinder is ready to fire and receives its "spark, the first cyclinder the also receivesa "wasted" spark "copy" of the one needed by the second cylinder. Economy is achieved in manufacture because otherwise electronics would have to turn on and off four different spark coils to distribute four different sparks as needed to the four cylinders. With wasted sparks (which are cheap), because the spark current of one coil is connected (internally in the ignition coil unit) to two cylinders that are in the same position but 180 degrees out of phase in firing, the system can turn on and off two spark coils twice as fast with half the electronics and fire two cylinders that are 180 degrees out of phase. A four cylinder engine thus uses only two coils, a six cylinder engine, three coils, etc., in a wasted spark system.
Jul 27, 2008 | Subaru Legacy Cars & Trucks
Thule 2003 Chevy S10 Pickup - Extended cab - Xsporter Truck Rack Logo
623 people viewed this question
Top Thule Boating Experts
Tom Chichester
Richard Warren
Richard Warren
john cordey
john cordey
Are you a Thule Boating Expert? Answer questions, earn points and help others
