Question about Sewing Machines
My machine is sewing backward, would go forward what to do
    Top Expert:
  • Sewing Machines Master
  • 45,599 Answers
There is normally a small lever on the front of the machine near the drive end that is up to go forward and down to reverse
It is a great help when starting to sew that you sew about 1/2 inch then reverse the direction and then go to forward again and continue sewing
actions anchors the start of the sewing and the thread will not come undone
do the same at the end of the sewing and when you cut off the threads they will not unravel
Posted on Apr 13, 2015
My machine will not sew in the forward position...It keeps sewing backwards like it is in reverse.....Need help ASAP
All sewing machines have a gear lever. This is so you can sew a seam forwards and backwards. Consult your manual.
May 03, 2016 | Sewing Machines
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
Model sw2145. Cant remember how to stop backwards sewing
The direction control Forward/Backward is located next to the stitch length control on the main vertical hoiusing of the machine. Lever up for forward down for backwareds.
Dec 04, 2015 | Simplicity Sewing Machines
My machines stitches backward instead of forward.
There is a forward and reverse switch you are missing. If you have a pedal it is a matter of pushing the pedal the right direction.
Jul 26, 2014 | Singer Inspiration 4205 Mechanical Sewing...
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
Only sews backwards
You probably have it in the buttonhole stitch.
Mar 23, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Dec 31, 2008 | Singer 3116 Simple
Sewing machine only sews backwards
Make sure that the machine is in straight stitch forward and the stitch length is the highest level that it can go. If that doesn't make it go forward, you will have to use the old hair dryer trick. Take the top lid of the machine off and heat the inside with a heated hairdryer. Work the stitch length and the reverse until it frees up.
Dec 14, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
110 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
