Question about Red Shed Windmill, 10 ft
Where can I get assembly instructions?
It says easy assembly but does not tell you how to assemble
Need assembly instructions
if you bought it from ikea, the instructions are rubbish :)
towers are relatively easy to assemble as the plugs will only fit where they're meant to go.
if this doesn't help, can you tell us what instructions you actually need because unfortunately, we're not mind readers.
Apr 13, 2013 | Computers & Internet
Need assembly instructions and bolt sizes for a twin over futon bunk bed
Can you find out the make of the beds?
If you can look it up on the internet and order the correct sized bolts.
IKEA is easy.
kolbrun
Feb 14, 2012 | Baby Gear
Can you please tell me where I can download instructions to assemble ikea hopen queen bed?
Here is the list of available IKEA assembly plans:
http://www.ikea.com/ms/en_CA/customer_service/assembly_instructions/assembly_instructions1.html
Note that if the assembly plan you need is not available, a format the bottom of the page is provided for submitting to IKEA promising the requested assembly plan withing 24 -4 8 hours.
Mar 15, 2011 | Microwave Ovens
My whirlpool duet washer fills with water when not in use. How do I replace the water valve...is this the best solution?
Yes, replacing the valve assembly is the best solution to your problem. You should do it as soon as possible to avoid a flooding condition. It's pretty easy... the valve assembly is a single component that can be easy removed / replaced using simple tools. Here's how:
1. UNPLUG THE WASHING MACHINE AND TURN OFF BOTH OF YOUR WATER VALVES
2. Remove the top from the washer by removing the (3) screws from the rear face and pulling the top backward and slightly upward.
3. Unhook the electrical connections and hoses from the valve assembly
4. Remove the valve assembly by removing the (1-2) screws holding it in.
5. Buy a new valve assembly at your local appliance repair shop.
6. Reverse the removal instructions to assemble.
Good luck and happy washing!
Feb 11, 2011 | Washing Machines
I am trying to assemble a york 2001 multigym but i do not have a assembly manual. Can you help???
Go to this web site www.yorkstrength.com on upper right hand corner you will see customer support and look instruction download. Hope this help!!
Apr 07, 2010 | York Exercise & Fitness
Assembly instructions for boys bike
all new bikes come with assembly instructions
if there is no assembly book with the bike , don't buy it
Jan 05, 2018 | Cycling
Do you have an assembling manual for the Da Vinci Parker 4-in-1 crib? There is none in the package we received...
you should be able to get assembly instructions from their web site www.mdb.com and follow the links.
Assembly is pretty easy
Oct 09, 2009 | DaVinci Da Vinci Parker Room Collection -...
Removal of headlight assembly to change headlight bulb on 2007 gmc yukon xl. I see the two screws above but can't tell if there is more to removing assembly. seemed easy initialy, but can't figure it out....
I am not familiar with the model but the vehicle handbook usually contains instructions and diagrams on bulb replacement. If stuff has to be removed to change the bulb the book will usually tell you to take the car to your nearest dealer.
Many headlamp bulbs need a strong light, a mirror and a great deal of patience...
Feb 27, 2018 | 2007 GMC Yukon
Jardine Baby Crib Assembly instructions Model #DV601B4
Can you call the manufacturer or visit Babies R Us for the manufacturers phone#? We have the crib you have and so far no issues, fairly easy to assemble
Jun 09, 2009 | Baby Gear
Assembly directions for food processor
I had same problem and found answer on another website:
Front on machine is the one with the label on it.
One thing: the instructions aren't particularly clear on assembly. The bowl handle should be *toward* you when you lock it on the base, pointing toward you when you stand facing the label side with motor to right and bowl to your left. Then the lid just slides right on and when you turn counterclockwise a quarter of a turn it locks into place with no effort as the key slides into the slot and locks. I had this idea the handle should be on the backside of the machine, and it will fit on that way, but then you can't get the lid to fit securely.
Apr 06, 2009 | Black & Decker FP1400 Quick N Easy Plus...
Red Shed Windmill, 10 ft Logo
572 people viewed this question
Top Red Shed Garden Experts
ray gallant
Brett Duxbury
Brett Duxbury
Jean DeLauche
Jean DeLauche
Are you a Red Shed Garden Expert? Answer questions, earn points and help others
