Question about JVC SPPWA670 Subwoofer
Mu subwoofer dosent power up - JVC SPPWA670 Subwoofer
Dpx-u5120 dosent show subwoofer option in function mode , how to fix it ?
I manage to slove to my DPX-U5120 Subwoofer level adjustment. In STANDBY mode, Press the Main Volume button and turn to Setting, turn until you find the SW Preout, Swith to normal mode, its won't work if u switch to REAR
Go back to CD/USB Mode, Then Press the Main Volume and find Audio Adjustment and now u can find the Subwoofer Level , Sub Phrase and Sub LPF adjustment.. Um Glad i found this and Happy Setting
Mar 22, 2012 | Car Audio & Video
Just got Z-2300 and there is no power to the system whatsoever. Everything is plugged in correctly and still no power.
On The back of the subwoofer there is a switch like what you would find on the back of a computer. Just turn that on and it should work. if that dosent work try switching outlets or try use a power surge bar.
Dec 26, 2009 | Logitech Z-2300 Computer Speakers
My dual subs wont light up and my ndual tweeters wont either
check the wire connection with the lights then bulbs okay then look on the inside of the box for an extra wire for power for the lights if that dosent work
Feb 02, 2009 | Dual XNBP12D Car Subwoofer
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenterâ„¢ SW 200 with Clean Powerâ„¢ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
I got same problem as you
the player dosent realy give power to the subwolfer its more for the speakers. it should be the amplifer that is connected to the subs, also mite want to chek the settings on the amp
Jun 06, 2008 | AudioBahn AW1206T Car Subwoofer
Missing lead
typically i would say connect it in parallel to the right or left channel..assuming your system dosent have a sub woofer output and your subwoofer is powered
Mar 05, 2008 | JVC TH-S3 System
Help please
Check your power cable, for bad connections.
Make sure voltage dont drop below 10.8v.
Nov 30, 2007 | Kicker IX404 Car Audio Amplifier
Where do I connect passice subwoofer
How many terminals does your s woofer have?
accordianman
Nov 01, 2007 | Denon AVR-1507 Receiver
JVC SPPWA670 Subwoofer Logo
75 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
