Question about ASUS Computers & Internet
How do I fix a PC that beeps, but shows no display when I turn it on.
Asus Sabertooth 990fx Motherboard EVGA 560 TI 2gb Graphic Card
  • ROD GANDY Apr 17, 2015
    Hi Art Warfield, I want to help you with your question, but I need more information from you. Can you please add details in the comment box _____________________ when you turn on the computer how many beeps and how may short or long beeps, listen to them while, that information is very important to resolve you issues
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
Posted on Apr 12, 2015
Asus sabertooth 990fx r2.0 not turning on
Try replacing Ram with working matched sticks, and feel by hand for outside bet that hdd, but RAM would do what your explaining if not working or broken
Aug 02, 2014 | ASUS Computers & Internet
Flashing green light on graphics card and power wont turn on
a green light ain't nothing wrong with, red it probs with the card.
So in fact this has noting to do with your graphic card.... It's your motherboard.
Can you remove your graphic card and plug your screen in the onboard plug,. I forgot to tell to turn off power , before you begin. So not only turn off the powerswitch, then there's still current, pull out the powerplug, remove your asuscard and plug in a manual pcboard and manual mouse. If done, tell me what happens when you boot, nothing. are you able to use bios????
Nov 12, 2012 | ASUS Directcu Ii Top Geforce Gtx 560 Ti...
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
Nvdia 9400 gt on P5GD1-TML/S
Yes, your mainboard supports up to 2GB of DDR memory. That does not change if you add a graphic card. Windows XP 32 bit can actually address up to 4 GB of total memory including CD, hard drives, and video cache.
Note: Your mainboard only supports up to 2 GB, but newer boards can support much more memory, up to 16GB of RAM.
If you could install 4 GB of RAM in your machine, it would still work, but windows would only address as much RAM as it can use; the rest would go unused, so it would probably show up as 3.5 GB of RAM then.
Jan 05, 2012 | ASUS GeForce Computers & Internet
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Cant connect to the enternet.asus sabertooth motherboard.i show an orange light at mobo conection
sounds like you need the lan driver go here and look up your motherboard and download the drivers. http://support.asus.com/download/download.aspx?SLanguage=en-us If this doesn't work you may need a new lan card.
Jan 06, 2011 | ASUS Sabertooth X58 LGA 1366 Intel X58...
Want to konw that will new graphic cards work on my pc??
I suggest that you need to buy the SAPPHIRE Radeon HD 5770 1GB graphics card. It is compatible to your ASUS motherboard. It will display and work faster.
Dec 23, 2009 | Computers & Internet
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
EVGA 8800GTS g92 with ASUS P5VD2-MX SE
Suggestion 1: Try switching your Monitor's plug from one DVI to the other. This shouldn't do anything, because your graphic card should display the booting sequence on all connected monitors... however, doesn't hurt to try.
Suggestion 2: New graphic cards are quite a power-hungry monsters... are you sure your power supply is up to the task?
Your current configuration could help in this regard + the make, model and rated Wattage of your PSU.
Feb 17, 2008 | ASUS P5VD2-MX SE Motherboard
Graphic card
Do you have the 6-pin PCI-E power connector attached to the new video card? If you do it's possible you power supply is insufficient and may need to be upgraded.
Dec 18, 2007 | ASUS P5GV-MX Motherboard
Computers & Internet Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
