Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
What does code ic mean? - Dream Maker Spas Dream Maker Ez Spa Hot Tub
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
I have not seen an ic error code. I have seen ICE several times. So either you do not have the original pack that came with the spa or your display may be malfunctioning.
What is your hot tub doing while the ic code is pressent?
Portable Hot Tubs and Spas On Sale
Posted on Apr 13, 2015
Lg synch fault
I do not no what you mean by using 9381 ic? In the audio or setup menu there is a adj for audio delay . Without knowing the model code that is the best I can do?
May 31, 2013 | LG Televison & Video
No problem just need to know the year of my tv. GE 19GT356
not familiar with your model,but any ics inside will have a date code at the bottom(not all ics) eg.9746
means 1997,batch 46
hope this helps a bit
regards
steve
Apr 07, 2011 | GE Televison & Video
What do trouble codes 67,81, and 82 mean for a 1993 Chevy Astro Van? THX
67 a/c pressure sensor circuit or a/c clutch circuit failure
81 brake input circuit fault
82 ignition control (IC) 3X signal error
Dec 23, 2010 | 1993 Chevrolet Astro
The TV will not power on and the red light blinks 6 times.
This is a basic blinking error code table:--
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
But in most cases the power cord is "defective" as it's a common issue.try with new cable 1st or else follow the chart and replace the part as per coding chart on main board.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Panasonic TH-42PX60U Television
On my mitsubishi ws65909 I have a 2-2 power light error code, what does this mean? any suggestions, I tried to power it up and the power light comes on and then goes off after 15-20 sec's
the famous code error 2- 2 is for fault in power supply or faulty power supply board. this has to be checked.
and error 2-3 is fault in convergence ic.so both the error codes are near to each other.so check out both options. i advise first replace the convergence ic on the board and check.the cost of each convergence stk ic is near to $15 .there are two such ic on the convergence board and both has to be replaced.then check out.if the problem is same go for power supply board replacement.
the ic which you have to remove and replace is stk 393-110 both the ic looks same anve same number .
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 26, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Have problem with my Panasonic Model SC-HT790V. When I went to turn on my surrond sound received a code F61 what does this mean and how do I correct it
This is a protect code that means either the voltage regulator IC has a problem or the output amp IC is defective. Check with a local repair shop to get an estimate. The output amp pacs run between $75 and $95 for the part.
Dan
Nov 04, 2009 | Panasonic Audio Players & Recorders
Same problem powers on for a couple of seconds
If the code is two blinks short pause two blinks long pause then repeats then over 95% of the time it's because the convergence output IC's need to be replaced as they are drawing too much current. A 2-2 code means overcurrent shutdown.
Jun 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
N70 network
simple, reset your settings or soft reset but first backup your phone memory when finished get your mmc and resetnit....
Dec 07, 2007 | Nokia N70 Cellular Phone
Faut F489
This is for code f489 as well as f498 F498 means a problem with flash eprom IC; meaning that unit is unable to read the basic instructions from the eprom IC. Can be cuased by several; may simply be a "bad connection issue" at the eprom Ic or somwhere in the Bus line--defective Ic or corrupted information which may or may not be recovered with a "service recovery" disc.(not an end user procedure) First step; try resoldering Eprom ic being careful not to bridge pins. second would be to take the unit to a AUTHORIZED ONLY repair shop for a firmware or eeprom update. Good Luck
May 24, 2006 | Panasonic PV-D734S DVD Player/VCR
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
277 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
