Question about Garden
Where is the fuel filter located?
Was told by licensed retailer that fuel filter would be right under air filter . . . not so. Can you tell me where it is?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
What kind of mower ??? Most 21" walk behind mowers ONLY have screens in the tank
Most riders have an inline filter
ALL commercial mowers have an inline filter
inline means it's in the fuel line going to the carb
Posted on Apr 14, 2015
Were is the fuel filter in a 2003 honda civic ex someone told me it was under the back seat but the back seat wont come up.please help
On a 2003 Honda Civic the fuel filter is located along the firewall just a few inches to the right of the battery. Its the fuel pump that is located under the back seat.
Jun 29, 2012 | Cars & Trucks
I have been told that my 1997 Hyndai Elantra has two fuel filters. is this true?
All cars have two fuel filter, some have even three fuel filters.
The first one is in the fuel tank and the other one is in the engine compartment.
Hope that helps you out!
Aug 10, 2011 | 1997 Hyundai Elantra
I'm looking for the fuel filter on my car. I have a repair guide with a picture and I've been under my car a couple times trying to locate it with no luck. I'm told that it is an in line filter, but I...
Your fuel lines should be on the left side of the car. You should see 4 or 5 lines going down the left side, right next to the end, under the car. In line filter means the filter is on those lines. It should be back by the tire. Find the lines and follow them down, it will run right into the filter.
Feb 19, 2011 | 2004 Kia Optima
1988 volvo 760 turbo - trouble
The filter is located eather under the car at the driver or rider side door.
Other probs can be
Bad fuel pump
Clogged air filter.
Clogged injectors
Water in the fuel tank.
Clogged catalytic converter
Bad MASS air flow sensor
Bad Throttle position sensor
Timing is off
Jan 25, 2010 | 1988 Volvo 760
Locate fuel filter for peugeot 307
describing the process as i've done for my peugeot 307. may be it can help you.
Open the bonnet. Look where the Clutch & Brake Oil Pan is. Right under this on Engine there is a black plastic round shaped (sometimes a rectangular type box) with fuel pipes for inlet and outlet. If you look from battery side, there is a small plastic bolt mounted downside the filter. loose it and let some petrol bleed. If there is air, then you'll hear the air escaping sound with bubbles. Tight it and start (ignition to crank) the engine to pump some fuel in filter from tank. Repeat the same procedure 2-3 times and there should be no air in filter and your car should start smoothly.
Aug 27, 2009 | Electric Rc Airplane 12v Fuel Pump W...
Where is the fuel filter on a 95 ply voy. located
driver side engine compartment. sometime its under the car driver side frame.
Aug 24, 2009 | 2005 Dodge Caravan
2001 Hyundai Accent cranks, won't start
its the camshaft position sensor . Its located (atleast on my 1.6L) to the right of the front HOT plate the conection runs between the engine and the right side fan. easier to work on if you take off the air intake thats by the left front side of the battery. you will be working between the fan and the motor. only one bolt but is tricky so u need a 1/4 inch nuckle with a 1/4 extention. once located and you have the right tools it will only take 30 minutes to replace....dont forget to take off negative battery cable before you start.
Apr 07, 2009 | 2001 Hyundai Accent
Where is the fuel filter located for Buick Century 2001
The fuel filter is located underneath the car in front of the gas tank.
You have release the fuel pressure. Remove the fuel filler cap, locate the fuel test port on the fuel rail on the passenger side on the end of the right real fuel rail for a 3.1L engine.
3.8L engine yhr test port is located at the pressure regulator under the trim cover.
Aug 27, 2008 | 2001 Buick Century
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
