Question about New Bright Toys
Why did my car stop being able to go forward?
Was working fine but now only works in reverse, no noise when push in forward direction but does stop instantly. Have tried all 4 frequencies. Is still able to turn. Is it the controller or the car?
Cub Cadet 1045 hydro. Transmission not working. Bypass rod in. PTO and belt fine. Jacked up wheels spin in opposite directions. Forward and reverse pedal when pushed makes loud grinding noise.
This actually sounds like the top pulley on the transmission may be loose and the center hole worn out.
Depending on the actual sound though it may be a bad transmission - sorry. I suggest having a dealer mechanic inspect it.
Mar 04, 2017 | Cub Cadet Garden
2000 jeep grand cherokee won't move in drive
very confusing post, is it working fine or does it still not drive in forward gears?
Dec 11, 2013 | Dodge Cars & Trucks
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My son has a '91 Pulsar, 5 door hatch. When he changes into reverse, the gear "grates", we beleive the clutch needs to be adjusted, is this correct? (he has no bother with any other gear...
When the engine is idling and the gear box selector is in Neutral all the internals of the gearbox are rotating. Pushing in the Clutch disconnects the drive from the engine to the gearbox but it takes a few seconds for the gears in the box to cease rotating. All the forward gears have synchromesh so there will be no crunching noise ifa forward gear is selected immediately the clutch is pushed in before allowing the gears to stop spinning. On the other hand Reverse has No synchros and therefore selecting reverse before waiting a few seconds for the gears to stop spinning will produce the crunching noise you have described.
So it pays to wait a second or two after pushing in clutch before Reverse is selected to minimise the crunch and if the clutch appears to be working correctly in normal driving ,then no adjustment is necessary.
Dec 22, 2010 | Nissan Pulsar Cars & Trucks
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Forward does not work - 19.2 V New Bright Buggy
It is a problem with the circuit board. To my knowledge New Bright does not have anywhere that you can order the board.
Feb 23, 2009 | New Bright Remote Control Toyota FJ...
Toys Logo
221 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
