Question about GE Advantium 120 Convection/Microwave Oven
How to clean liquid under round grate oven base?
Spilled a large cup of coffee that seeped under the turntable and through the slotted (round) base of the oven. I can see pooled coffee but can not access it. Any ideas of of to clean? Will this cause issues with the appliance? Thanks.
    Habit-Forming:
  • 20 Answers
Avantiums are heavy. Underneath the turn table mechanically is only the turn table motor and the frame of the microwave. I would let it sit for a day and dry out before using it. But in the long run it might create corrosion and eventually you will need to replace your turn table motor. But I have seen liquid spilled into the turn table motor and be fine. You may create more damage by uninstalling your microwave to clean up the spill.
Posted on Apr 13, 2015
    Top Expert:
  • GE Master
  • 44,375 Answers
Tip it toward the back and be prepared to wipe up a big mess
Posted on Apr 12, 2015
Testimonial: "Thanks - forgot to mention it's a built-in cabinet. We're going to uninstall the appliance & tip over. Was hoping there would be an easier way! Thanks."
  • ray gallant Apr 12, 2015
    well you could drill a small hole into the bottom but I would not recommend that
Sounds normal when running but will not heat food and turntable does not work
You didn't specify a particular model, but the no-turntable and no-power symptoms are likely linked. Many microwaves have sensors to the turntable motor to tell if something being heated has been run into a wall (round turntable in a rectangular box, it can happen), Depending on the model, it may reverse direction, or it may just stop turning. This is both to keep from mucking up any reduction gearwork likely at work to turn some small motor spinning at a higher speed into a big table with a few pounds of food turning slowly with reasonable torque. It also will stop so that things won't get tipped over - no good to anyone if a poorly chose top-heavy bowl full of scalding liquid gets tipped over, flooding the microwave and burning whoever opens the door.
So... I'd remove the carousel plate, if possible, and see if the base is all gummed up with old spilled, ultra-baked-on crust or gummy residue. if so, between washcloths with scalding water and some gentle cleaner, like Simple Green, try to clean up the area and remove what might be freezing the spin shaft up. See if you can wiggle the shaft or turn it slightly with fingers or a small pair of pliers. If not, there may be more stuff gummed up further down the shaft. Don't expect to just spin it, it's probably tied to a motor with a belt or gear assembly that will put the mechanical advantage working against you.
After that - you can try unplugging the oven for a few minutes, in case it's either overheated, or in a 'safe' mode, or look for an owners manual for your specific model to see if there's a button combo to reset things, (or accessible fuses).
Good Luck!
Nov 13, 2015 | Microwave Ovens
I have an LG solardom microwave and when I want to heat a small amount of liquid, it sparks and the base(not the turntable) of the microwave gets hot.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
Nov 24, 2013 | LG Microwave Ovens
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My Sharp R957 turntable seems to be sticking. I've cleaned under the turntable and the support but it doesn't seem better. If I give it a push it works for a bit then slows down again.
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 16, 2011 | Sharp Microwave Ovens
GE microwave oven squeals as carousel is rotating. Noise stops in a minute or so but begins anew when the unit is used again.
If it is the wheel on the turntable that squeels, wash the turntable in strong solution of washing up liquid and water.
If it does it without a turntable fitted, change the turntable motor.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 01, 2011 | General Electric Microwave Oven
My Sanyo microwave oven is six months old. The turntable has stopped rotating smoothly. Its motion has suddenly become jerky and noisy at the same time. I have given it to the vendor who sold it to me, for...
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Since it's less than one year old, it should be fully covered under warranty, as long as the problem is not due to grease or liquid spilled down into the motor.
Nov 29, 2008 | Microwave Ovens
Trim Kit for Over stove GE Spacemaker 1800
i think i am having the same problem, i spilled a cup of coffee inside of the microwave as i was reaching to get it and the turntable stopped rotating since then. what do you think could be the problem and how could i fix it?
Oct 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
148 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
