Question about Home
WAter is coming out of the bottom on the left hand side. Taking the cover off yields no information, the fault lies deep inside somewhere.
The machine is brand new and was only installed last Friday.
    Top Expert:
  • Home Master
  • 52,086 Answers
Self installed no doubt we have no idea what MACHINE this is now do we
Posted on Apr 12, 2015
Testimonial: "I have already said it is a Triton T80Z fastfit. A registered electrician installed it ton Friday last and there is no customer service from Triton over the weekend."
  • 2,899 Answers
We have no idea what your hardware is. More information may help us to give you an idea. If the device is new, you can call the installer and have it serviced under warranty.
Testimonial: "I have already said this. It is a Triton T80z fastfit electric shower. It was installed by a registered electrician last Friday and had to be isolated immediately due to the fault."
  • ray gallant Apr 12, 2015
    there is and was the problem plumbers do much better job when it comes to water
  • Jay Plesset Apr 12, 2015
    I've looked back at your original question, and see no mention of "triton". I agree a plumber may be your best bet. If there are instructions, they may show you where the water cutoff valves are. Turn it off until you can get help.
Weve just bought a new bush dishwasher we used it for the first time and it come up with E1 when i opened it the water had not drained
The E1 code indicates a fault with either the machine or the way outlet hose is installed.
If it was installed by a third party give them a call.
If you installed it yourself have a good look at the user guide and see if the placement of the hose could be improved. Make sure there is not a 'dog-leg' bend in the hose. If the error code persists call the supplier as it might indicate a fault with the machine.
Jun 25, 2016 | Bush DW12TFE3 Dishwasher
Customer service
This is not customer service for Zanussi
Jul 17, 2014 | Zanussi Washing Machines
Frigidaire FRS26HF6BW2 side by side Refrigerator, water out of valve ok with good pressure but no water enters the filter, unable to disconnect water line input to the filter to see if clogged. How to...
The plastic feed line from the inlet valve in the bottom right hand side of the back going up to the top left hand side feeds the filter. You can shut-off the water from the house tap, and then cut the plastic filter feed line in the middle somewhere, and install a john-guess coupling on the inlet valve end of the cut line. Then you can tip that line into a bucket, turn on the water tap and see if water comes out into the bucket, if it does, then proceed to the next step.
Sometimes the filter cartridge has a thin piece of plastic that remains on the cover, obstructing the water inlet ports in the filter housing. Always use a mfg.'s specified filter, not a Chinese "Knock-Off".
Oct 31, 2013 | Frigidaire FRS3R5EMB Side by Side...
Error message: black cartridge unsupported
Make sure that your printer firmware is updated. Please visit the Lexmark website to download and install the Lexmark Firmware Update. Select your corresponding model to start the download.
Should the error message continue to display after successfully updating your printer, try to re-seat your black cartridge in the printer.
If that doesn't help, please contact Lexmark Technical Support Center for further assistance. Thanks.
Jan 10, 2012 | Lexmark Office Equipment & Supplies
Just received brand new Austin Allergy Machine Friday April 29, 2011. Funny odor coming out of outgoing air. I have mold, smoke, pet dander, allergies, chemical sensitivities to deal with and I don't think...
Have a Indoor air quality inspection preformed in your house. Then spend the money to have a air purifier installed for the whole house. In this day you often get what you pay for. It may be possible that your Doctor can provide you with a prescripition for the Air purifer to be installed.
May 02, 2011 | Austin Allergy Machine Air Purifier
My F&P dishwasher (Nemo) stops mid cycle and empties the water. It then indicates a fault by flashing the Start/Reset light 7 times and the Rinse light comes on.
hi did you find the solution or what the 7 flashes mean as my dishwasher is doing the exact same thing.
thanks
jane
Jan 26, 2011 | Dishwashers
I have a LG washing machine Model # WM2688H*M it has a slight leak that I traced to a small black hose. The hose is in the back of the machine that goes from the bottom of the drum to the top somewhere...
It's not likely the hose is leaking, but rather water is leaking from somewhere else and is running down the outside of that hose. Remove the washer top by taking out the two phillips head screws from the bottom of the plastic clips on the back side of the washer's top. Now, stand in front of the machine and use the palms of you hands to sharply push the top cover back about 2 inches, then lift the cover off. Look for the water leak. The most likely suspect is a water inlet valve.
Jan 01, 2011 | Washing Machines
Washer still has water wont empty?
Chances are you have a blockage or pump fault, try lowering the outlet hose into a bucket or bowl, if water flows then it is a pump or associated wiring fault but if no water comes out or very little then you have a blockage probably in the sump. If this is the case then tilt the machine back, open the door and bale the water out with a mug or sponge, now tilt the machine forward and remove the lower inspection plate on the bottom at the rear of the machine. keep the machine tilted forward by placing a tin of soup or something under it. Put a bowl or deep dish under the sump(the black hose connected to the under side of the drum)to catch any water that will come out, now remove the clip that holds it onto the drum. the filter is inside the hose.Disconect from the mains power before commencing any work.For Hotpoint, Creda and Indesit error codes and help visit Selfix-uk
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Home Logo
232 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
