Flashing power and cycle light.
Half way through cycle before taking the softener all the lights begin to flash and machine stops. Do you have any idea what I should do? I have turned off taken laundry out put a lighter load in etc however it keeps on doing the same thing. Thank you in advance.
    Top Expert:
  • Washing Mach... Master
  • 43,095 Answers
Try a different cycle but suspect the timer has failed .
Posted on Apr 12, 2015
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
What does E50 flashing on a Aeg washing machine
Your Water inlet valve is bad or has failed! You need replace either Hot or cold valve.
Jul 25, 2014 | AEG Washing Machines
Can't get machine to start a cycle. When press the start/pause button, the door open light begins to flash. After a few seconds, it stops flashing and the start/pause button begins flashing. I have checked...
It is hard to tell if there is no model number. Normally, WP machine has error code appeared on the display. I guess your unit does not have display, so the combination flashing is a signal to tell you what wrong with the system. You can check the service manual normally taps inside the unit.
Oct 22, 2013 | Whirlpool Washing Machines
Kenmore HE2 washer will not automatically advance through all the cycles
I had this same /similar problem with my machine and found that the micro-computer board on the top rear near the cover of the machine are very prone to having bad electrical contacts on the board where the wire connectors go. The answer simply was to remove this board and add solder to each and every solder pad that goes to the connectors. The board is not bad (defective) just poor electrical connections.The repairman probably just wiggled the 1 with the issue and it worked for you for months as described! Perhaps you could get away with just disconnecting the electrical connectors and plugging them back in -it could buy you some more time before fixing it permanently with solder!
Good Luck!
Rich Lilja
Mar 05, 2017 | Kenmore HE2 Plus Front Load Washer
The stain vanish and 90 minute lights are flashing but the cycle has'nt finished.begins to spin but makes a banging noise and then stops.not taking fabric softener neither.
Sounds like multiple problems. A banging noise during spin means that the drum is not centrally balanced or the suspension mounting is loose or broken. The machine needs to be examined by an experienced technician.
May 27, 2011 | Washing Machines
Flashing container light. what is this? Dryer
Try taking out the lint screen and scrubbing it well in the sink with hot water and a brush. If you havent cleaned out below the lint screen, get a vacuum and a crevice tool and remove any standing lint as well as cleaning the vent. Bosch lint screens clog easily especially if you are a big fabric softener user.
Nov 20, 2010 | Bosch Classixx WVF 2402 Front Load...
No Drain light flashing on washing machine
ckd for something stuck in pump newer models have a low torque electric pump easily stalled by lint or even tooth pick
Jun 01, 2008 | Westinghouse Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
