Question about Stihl Garden
I have fuel leaking when I turn my stihl ms310 chain saw on it's side to refuel what's the problem?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The first thing I'd suggest is to check the vent on the fuel tank. It should be either a molded plastic slip-on device that attaches to a stub on the top of the tank or it will be a small hose that does the same thing. Inserted in the end of the small hose, if so equipped, should be a tiny, tiny, tiny set screw which serves as a 'restrictor' to allow the tank to vent but not the gas. Either the tube has fallen off, cracked or the restrictor is missing.
Posted on Apr 13, 2015
    Top Expert:
  • Stihl Master
  • 43,030 Answers
Split plastic hose replace it
Posted on Apr 12, 2015
Where to get points for 016 stihl chainsaw?
Stihl Chainsaw Parts ' Chainsaw Parts ' Discount Online Parts
https://www.discountonlineparts.com/chainsaws/?b=stihl
  1. Cached
  2. Similar
Quality Stihl replacement parts, cheap and quality available online.Handlebars and Housings · ‎Bar/Chain Combos · ‎Stihl 041 Cylinder Assembly ...
Stihl Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b354/Stihl-Chainsaw-Parts
  1. Cached
Stihl Chainsaw Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Chainsaws ' Parts, Accessories, Reviews & Pricing ' STIHL USA
https://www.stihlusa.com/products/chain-saws/
  1. Cached
Choose from the wide selection of reliable, dependable and high performing STIHL chainsaws with low-emission technologies and quieter, more fuel-efficient ...Homeowner Saws · ‎Professional Saws · ‎Farm & Ranch Saws · ‎In-Tree Saws
Stihl Chainsaw Parts ' eBay
www.ebay.com/bhp/stihl-chainsaw-parts
  1. Cached
  2. Similar
Find great deals on eBay for Stihl Chainsaw Parts in Garden Chainsaws. Shop with confidence.
Home ' STIHL
en.stihl.ca/index.aspx
  1. Cached
  2. Similar
STIHL - Information about the STIHL Group and our extensive range of chain saws and ... About us More than the world's most successful chain saw brand. stihl chainsaw Google Search
Nov 23, 2016 | Stihl Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
www.stihlusa.com/.../ms-261-261c-chain-saw-instruction-manual.pd...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
Keep burning up piston on exhaust side of 066 stihl on second jug and piston i know oil mix is right running three other stihl saws on mix
It sounds like you are running lean. Not a lean oil/gas mix but a lean Air/fuel ratio. This engine runs hot as a high performance engine. any air leaks such as crank seals, manifold gaskets or muffler gaskets can give you too much air for the fuel coming in.
Secondly from the fuel side:
Ethanol (curse it) combines with oils that have no nondispersants making a white chalky poweder in the fuel system causing less fuel to mix with air. any blockage or pin hole leak can cause less fuel to be brought into the engine thus less cooling and lubricating.
Your carburetor and fuel filter need to be serviced and adjusted correctly or they will affect the mix.
When done the engine should run no faster than 13,000 rpm top no load speed.
This engine should idle smoothly at 2,500 with no more than 150 rpm change
if the speed is not as listed above when the rebuild is done you need to go back into the machine.
Call up a shop like www.arcolawn.comto get a EDT8 tach. it is well worth the money.
good luck
Joe
Nov 14, 2010 | Stihl Chain Saw Handle Models 064 066...
Petrol leaking when turned up side down,Ryobi Chainsaw
Upside down is not a usual sawing position--only upright, or turned to the left or right side is recommended. If you need to undercut something, keep the saw upright and cut with top side of the chain/bar.This can lead to kick-back if the tip comes free of the log/branch, so you need to control the saw carefully. That's also why there is a chain brake on all newer saws. The leaking may be occurring where the fuel lines pass through the wall of the fuel tank. Hope this helps!
May 04, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Mar 25, 2009 | Poulan ES350 16" Chain Saw
Garden Logo
188 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
