Question about Husqvarna Zero Turn Mower RZ4619
Zero turn will not move forward reverse or turn
While mower is running it will not move when you push the handles forward reverse and just sits there the mower is running and the blades are engaged
    Master:
  • Husqvarna Master
  • 645 Answers
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Posted on Apr 27, 2015
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
SOURCE: Engine runs good and blades turn fine but the
the freewheel control is in the wrong position. push in all the way for mowing. This control is located on the rear of the mower below the seat.
Posted on Jun 08, 2009
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
mouse_kil
  • 93 Answers
SOURCE: moved mower out of shed to sharpen blades, moved
with out knowing the exact make and model my only suggestion is look for a lever on the back --usually on the rear right hand axle which disengages the drive some one may have moved the lever when the blades were getting sharpened.
I hope this helps
Andrew A
Posted on Apr 18, 2011
  • 6468 Answers
SOURCE: Husqvarna zero turn mower backfires and stalls when mower blades on
sound like a carb problem clean the jets out
Posted on May 20, 2012
Gravely zt 48hd starts, blades engage and start, but mower will not move forward or reverse after lowering brake. suggestions?
There should be a lever/engagement clutch on the back of the mower. It is disengaged when you manually push it. It will have to be engaged again to allow it to move.
Jun 24, 2016 | Garden
After the mower is used for awhile and the direction controls are pulled back to go backwards the blades stop and when the controls are pushed forward the blades do not reengage.
George, this is a safety feature built into the mower, the switches can be unplugged, but remember they were in place for your and others safety.
Mar 22, 2016 | Garden
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Husqvarna Zero Turn Mower RZ4619 Logo
726 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
