Question about Garden
How to re string a Murray m2500 weed eater - Garden
#1 Taper
  • 1040 Answers
SOURCE: Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
  • 65 Answers
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Posted on Aug 22, 2009
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
heatman101
  • 43501 Answers
SOURCE: how do i install newstring
Try this out...
http://www.ehow.com/how_4914620_restring-black-decker-weed-eater.html
heatman101
Posted on Jul 23, 2010
kjhbegrt
SOURCE: Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Posted on Jan 10, 2015
Very hard to start the Murray M2500 weed eater
replace the diaphragm in the carby( note her e--kits are as costly as a new carby so check on e-bay for a replacement price
don't use e-mix fuels in small engines
Aug 20, 2016 | Garden
How do I find a detailed diagram of a Murray string grass trimmer CARBURETOR/
Hi Patrick,
If you hit the link below and scroll toward the bottom of page you will find videos that should be very helpful.
http://www.ereplacementparts.com/mtd-m2500-41adz01c758-gas-trimmer-parts-c-20039_20040_299701.html
Good Luck!
Mar 22, 2016 | Garden
How do i change a coil wire on a murray 2510 weed eater?
Murray Trimmer Product Support ' ManualsOnline.com
www.manualsonline.com/support/murray/trimmer/
Does Murray Weed Eater MS2550 use straight gas or. Murray ... HOW CAN I DOWNLOAD MURRAY 2510 TRIMMER MANUAL??? Murray Trimmer M2510.
Mar 13, 2015 | Garden
Morrison weedeater
never saw your brand weed eater . but most weed eaters ,the string cap either unscrews or has plastic tabs that have to be pushed sideways with a flat blade screwdriver.If you have the plastic tabs ,be careful not to crack them off when pushing them sideways with a screwdriver--- so that the nub can clear the slot and get the cap off.
for better info call morrison customer service and ask.
phone # on weed eater and in owners manual. also , owners manual should have instructions under how to change string.
a pdf manual can be downloaded from morrison weed eater.
you will need to know your model number before morrison can help you.
Oct 06, 2013 | Garden
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Garden Logo
198 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
