Question about Craftsman Garden
I have a Craftsman 917.370441. I need to replace bolts at the bottom of the handles that goes through the deck. I can not remove the plastic shield under the deck so I can replace the bolts.
How do I remove plastic shield under deck.
  • Rob Melbe
    Rob Melbe Apr 12, 2015
    It is a push mower
    Top Expert:
  • Craftsman Master
  • 10,875 Answers
You either unbolt it or you take off the tires,there is no shield listed only the rear door,you access inside through the door,here is a diagram, http www searspartsdirect com craftsman walk behind lawn mower parts model...
Posted on May 20, 2015
canbruce75
  • 1776 Answers
SOURCE: How to replace drive belt craftsman tractor
There is a video on YouTube that may help you somewhat with the belt replacement. You may want to check it out. Here is the link. Sure hope this helps and best wishes.
http://www.youtube.com/results?search_query=lawn+mower+belt+replacement&search_type=&aq=1&oq=lawn+mower+be
Posted on Aug 25, 2009
Testimonial: "Good, quick feedback - thanks --"
  • 3 Answers
SOURCE: Need image, assembled craftsman model 917.276813 lawn mower deck
http://afternoon-tea.bordadom.vu.cx/index.html italian wine bar
[url=http://afternoon-tea.bordadom.vu.cx/index.html]italian wine bar[/url]
<a href=http://afternoon-tea.bordadom.vu.cx/index.html>italian wine bar</a>
Posted on Aug 26, 2009
bbreton
  • 437 Answers
SOURCE: need to remove pulley from spindle to replace
If you do not the facilities to use an impact wrench, you will need to find to hold the pulley and you a breaker bar with a socket on it to get the pulley nut loose. I would use either"PB Blaster or Deep Creep" penetrating oil and spray it on the nut before you try to take it apart.
Or you may find a professional shop, take the deck to them and may may take the pulley off for a small fee.
Posted on Sep 28, 2009
  • 3074 Answers
SOURCE: I have a 17hp Craftsman
impact gun is the easiest way, if not the you will need to use a pipe wrench and a ratchet. Hope this helped Tim
Posted on Mar 28, 2011
  • 5370 Answers
SOURCE: Cub Cadet Series 1000 Model
For step by step instruction to replace or re-fir drive belt and for service and owners manual.click this link below:---
http://technoanswers.blogspot.com/2011/06/service-manual-for-service-manual-for.html ------------- This should help.thanks.helpmech.
Posted on Jun 21, 2011
How do I install the deflector shield on a Craftsman LT1000 lawn tractor, model # 917.274351?
Have you checked if it has a nut on the other end which is just turning round with the bolt ?
Sep 01, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How installation a starter in biuck regal ls 1999
Make sure your battery is disconnected. On the starter, remove the wires, and the stay bracket, if any, on the front of starter. Underneath car, there is a plastic shield held on by two bolts or screws. Use a 10 mm wrench and remove the plastic shield. Use a 15 mm socket to remove the starter bolts. There are two that hold starter from the bottom. In other words, bolts are mounted from the bottom, and go up into the block. Once you have it free, you may need to use some ingenuity to turn, position it for removing from that small space to bring it out from car. New one goes in same way. If there is a shim between starter and block mating surface, be sure and use it with new starter.
Oct 26, 2011 | 1999 Buick Regal
I have a dual blade deck on a Craftman's 15.5 OHC rider mower that needs to be greased. The blades make a loud racket when they are engaged. Any idea where to grease the mowing deck?
look closely and you will see the blades under the deck are physically bolted to the same gizmos which are spun by a belt on top the deck. these gizmos are called mandrels, and that is where the lube has to go. sometimes the top of the mandrel has a grease fitting and you may have to pull the deck safety shields off to get to them, and sometimes there are grease fittings on the bottom of the mandrels and you have to pull the deck off and turn it over to get to them. Then sometimes they are "lubed for life" with no grease fittings and you have to go to a small engine repair shop and buy new ones. if you get the deck belt off and there is any slop in the mandrel, then you are too late for grease and new mandrels are in order. they cost less than 50 bucks apiece. generally remove the deck, the blades, the belt, the pulleys, and a few bolts and nuts and reinstall new in reverse order. replace all the belts while you are at it.
Aug 07, 2011 | Craftsman Garden
How do I install the deflector shield on a Craftsman riding mower, model # 917.288031?
Hi and welcome to FicYa, I am Kelly.
You will need to make sure that you have items 21 - 29 of this diagram: Scroll way down 75% until you see the deck and belt, then look at item 27 the deflector shield.
http://www.hammerwall.com/Manuals/Craftsman/Description/917.288031/Craftsman%20Lawn%20Tractor%2017.5%20HP%2042%20Inch%20Mower%206%20Speed/L0807249/
It is a matter of sliding the bolt throught bracket on the mower deck and making sure that the shield safety switch is actuated. (Flip up)
I also read the owner's manual (no help!). The only thing about the shield is on page 14 stating to make sure it is in place.
If your missing the hardware to install the deflector shield you can go to http:www.searspartsdirect.com and enter your model number in the search bar. You have to choose model search then click (go).
You will get this diagram if you choose mower deck:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917288030/0247/1509200/P0905008/00007?blt=06&prst=&shdMod=
Thanks for choosing FixYa,
Kelly
Apr 30, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I get the bolt off the top of the housing assembly in order to replace the mandrel #137646? Besides a wrench what other tool do I need to accomplish this? RIght now the bolt won't loosen because I...
If your blade will secure on the star, just jam the blade with a block of wood and proceed. If you have ruined your star, remove the three bolts that secure the mandrel housing, allowing the pulley to drop down to the deck (this requires some room beneath the deck, so get the whole thing off the ground first) and secure the pulley with heavy wire to the deck. There are a couple holes in the pulley and those bolt holes in the deck. Twist tight. The nut is threaded normally (counter clockwise to remove). A socket with a long handle does the trick after you use a few drops of break free oil.
Sep 06, 2010 | Craftsman Garden
I am trying to find out how to replace the mower belt of my 2006 LT2000 23hp Craftsman lawnmower
Replacing the belt is easiest if you drop the deck. There are roughly 6 pins you must pull (refer to sticker on deck) including the engagement cable. Pull the deck from under the tractor and remove the plastic pulley shield from the left side. Remove the belt and replace the same as you took off and re-attach the deck to the mower.
May 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman mandrel replacement::?????HELP
You dont have to drop the deck. Remove the belt first then hold the blade in place so you can loosen the nut on top of the pulley. after you remove the pully then remove the blade. There are 3 bolts holding the mandrel in place remove the bolts. Then pull the mandrel out from underneath the mower deck. There is a shroud that will come loose with it or it may stick from accumilated grass regardless it needs to go back during reassembly. When putting it back together the 3 bolts are usually self tapping into the new aluminum mandrel. Its much easier to put these in and take them out before you install the new mandrel as the bolts cut the threads.
Hope this helps
Brent
Jun 23, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Replace exterior driver door handle
If you remove the inner door panel of the door there will be plastic weather shield covering most of the door. Use a hair dryer or heat gun to heat the weather shield up and slowly peel it away. There will be 2 (10mm I believe) bolts on the inside of the door panel to release the handle (have someone catch it from the other side). To re-install simply connect he handle rod and 2 bolts then place the door panel back on and your done. A word of advice is be gentle with the door panel so not to damage the door pins or crack the plastic. Taking your time can be fun when learning a car ;).
Jul 03, 2008 | 2000 Toyota Corolla
Garden Logo
127 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
