Question about Karcher K5.540 2,000 PSI 1.4 GPM Electric Pressure Washer
Frost damaged unit is leaking
I forgot to add antifreeze this winter and now my washer is leaking. What parts are normally needed to repair this type of damage. Is there a service centre in Calgary, AB, Canada?
    Habit-Forming:
  • 78 Answers
Sorry to say you need a new power washer it would cost you to much to just replace the pump
Posted on Jul 24, 2016
2 Suggested Answers
CaptAdams35
  • 28 Answers
SOURCE: karcher power spray frost damage
I've found the most useful repair people for power washers are lawn mower repair techs. Give them a ring and see if they do house calls, they'll be your best bet.
Posted on Mar 09, 2010
Is it nessasary to use anti-freeze for winter storage?
Yes it is highly recommended to use antifreeze when storing a vehicle over the winter, as if the temperature drops below freezing, just water in the coolant system can cause various damage throughout. Most combustion engines have a frost plug in the block, but they are not fool proof, and extreme cold can cause the block, heads, intake manifold, water pump, or even the rad to split. It is also recommended to add a fuel stabilizer before storing a vehicle for a lengthy period of time.
Oct 12, 2017 | Cars & Trucks
Tip
Winterizing a Washing Machine
If you keep your washer in area where you need to winterize for the winter (unheated garage or unoccupied vacation home), the following steps may provide you with some helpful guidance in preparing before extreme temperatures occur and possibly leave you with damaged plumbing and/or a ruined appliance.<br /> <br /> <b><u>TOP LOADERS</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub, and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. STOP or CANCEL the timer on the washer and UNPLUG.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. Clean the detergent dispenser and fabric softener dispenser and ensure they are dry.<br /> <br /> 8. Store washer, unplugged in an upright position.<br /> <br /> <br /> <b><u>FRONT LOADER</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. Press PAUSE/CANCEL twice to halt the cycle and UNPLUG the appliance.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. IMPORTANT: Check the perimeter of the door bellow (gray rubber seal) and make sure no small articles of clothing are left in the rubber folds. Clean this area thoroughly and dry. NOTE: Anything left behind will mildew over a period of time causing foul odors.<br /> <br /> 8. Clean the detergent dispenser drawer of any remaining water or fabric softener residue.<br /> <br /> 9. Store washer, unplugged in an upright position.<br /> <br /> <b><i><u>Secondary Method</u></i></b>: <br /> <br /> If you cannot find RV antifreeze (or prefer not to use it), another method of draining the washer is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. This will pull any remaining water from the drain pump and lines. <br /> <br /> If a shop vac is not available, lowering the drain hose from the standpipe to the floor will allow it to drain using simple gravity. <u>IMPORTANT</u>: On a front loader, you may have to remove the drain line from the drain pump to drain the pump. Or, use the access cover (if equipped). Most front loader pumps are accessed by removing the lower panel directly below the door.<br /> <br /> <b><i><u>Taking the Washer out of Winter Storage</u></i></b>:<br /> <br /> To remove antifreeze from the washer following storage, run the appliance on a complete cycle with detergent and NO garments added.<br /> <br /> I hope you find this information helpful. If you have any questions, please let me know.<br /> <br /> <br />
on Aug 09, 2011 | Washing Machines
Can you put just plain water in the radiator
no because the the engine would overheat and blow ahead gasket or freeze in winter put put 50%antifreeze and 50%water or 50/50 antifreeze
May 08, 2012 | 2002 Dodge Durango
Dipping of rusty water
yep heater core in dash leaking,sound like heater core rusted out if you used straight water.you need to have radiator and engine block flushed because rusty water is in the entire coolant system, you need flush coolant system replace thermostat add 50/50 antifreeze and water mixture never run straight water because straight water in winter weather will cause water freeze up in cylinder block and crack cylinder block you need antifreeze mixture in coolant system to keep coolant from freezing.
Dec 01, 2011 | 2005 Kia Spectra
I need to add coolant to my 2004 honda shadow and I am wondering if there is a certain type of coolant I should add.
Use any motorcycle manufacturers coolant, GM Dexcool, or any NON-Silica style automotive style coolant. You do not want rust scrubbing particles in your antifreeze. The scrubbing particles will damage the ceramic washer in your water pump seal. Add the antifreeze to the motorcycle with the engine cool. Be sure to add coolant to the overflow bottle and the radiator cap. Most motorcycles do not have enough volume of antifreeze in the engine to draw the coolant from the bottle alone, so add coolant at both points.
Jul 09, 2011 | 2004 Honda VT 750 Shadow Aero
Opened the coolant resovoir and the coolant was frozen
Please add antifreeze on your coolant to prevent this situation. A frozen coolant is dangerous to your car.
Jan 13, 2011 | Chrysler 300M Cars & Trucks
Where do I put antifreeze in the car
what kind of antifreeze?...radiator fluid?...if Rad fluid..look for your overflow tank, and add it there. The cap may be yellow, and may have "rad fluid only" printed on it.
gas line antifreeze goes directly into the fuel filler
windshield washer winter(antifreeze) goes into the wishy washy reservoir
Jan 06, 2011 | 2002 Nissan Altima
No pressure forgot to winterize
These aren't bad pumps but they do wear, and they cannot take idling without moving water. If you don't have a temp sensor add one to provide some flow if you idle too long. You can find parts at www.pressure-washer-parts.com
Jul 06, 2010 | Annovi Reverberi 3000psi 35gpm Pressure...
How often do I need to service a BMW 123d?
Hi and welcome to FixYa. I am Kelly.
Here are your service intervals:
NOTE Besides Oil changes there are inspection intervals I & II
http://www.savagebmw.com/Service/content_service_Intervals.htm
Inspection interval I
BMW Inspection I (return to top) Undercarriage
  • Change engine oil and filter while engine is at normal operation temperature.
  • Check transmission for leaks.
  • Check rear axle for leaks.
  • Visually check fuel tank, lines, and connections for leaks.
  • Check condition, position, and mounting of exhaust system. Examine for leaks.
  • Check power steering system for leaks.
  • Check overall thickness of front and rear disc brake pads.
  • Examine brake disc surfaces.
  • Clean brake pad contact points in calipers.
  • Grease wheel center hubs.
  • Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
  • Check front control arm bushing for wear.
  • Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
  • Check for free movement of the parking brake cables. Adjust parking brake if necessary.
  • Check all tire pressures (including spare). Correct if necessary.
  • Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Engine Compartment
  • Read out diagnostic system
  • Check engine cooling system/heater hose connections for leaks.
  • Check coolant level and antifreeze protection level; add coolant if necessary.
  • Check level of brake and clutch fluid in reservoir; add fluid if required.
  • Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
  • Check air conditioner for operation.
  • Reset Service Indicator.
Body/Electrical Equipment
  • Check battery electrolyte level and add distilled water if required.
  • Perform batter load test.
  • Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
  • Check instrument panel and dashboard illumination.
  • Check all warning/indicator lights, check control.
  • Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
  • Check wiper and washer system(s); wiper blades, washer jet positions.
  • Check condition and function of safety belts.
  • Oil hood, trunk/tailgate, and door hinges.
  • Grease hood, trunk/tailgate and door latches. Check operation of all latches.
  • Check central locking/double lock.
  • Replace microfilter or Acc. Cabin Filter.
  • Check heater/air conditioner blower, rear window defogger.
  • Check rear view mirrors
  • Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
  • Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Inspection interval II
BMW Inspection II (return to top) Undercarriage
  • Check thickness of parking brake linings.
  • Half-shafts; check for leaks at flexible boots.
  • Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
  • Replace spark plugs (as applicable by year and model)
  • Replace intake air cleaner element.
  • Replace microfilter or Acc Cabin Filter.
Final Inspection
Service indicator lights if installed:
http://www.savagebmw.com/Service/content_service_IntervalsLED.htm
That should just about cover the works other than failures.
Thanks for using FixYa!
Kelly
Feb 16, 2010 | 2008 BMW 1 Series
The windows keep fogging up this winter no matter
Hello gebb.
There are a few problems that can arise to cause this issue.
First of all, do you have an odor inside the car and does it leave a film on the windshield that is hard to remove? If so your heater core is leaking antifreeze into the plenum and being blown inside the car. Replacement is necessary to repair.
Next is a possible simple issue, the recirculation door if closed will pull all the air supply for the blower fan from inside your car. The air inside is moist and will never defrost the windshield. Make sure you turn off recirculation.
Next issue is your air conditioner system. If your A/C system has quit working you may notice more moisture inside your car. When you turn on your defroster it activates the A/c compressor. When it comes on it makes the incoming air pass over the very cold evaporator inside the plenum. The water vapor condenses on the cold surface and is removed from the incoming air.
Next is a possible leak into the interior of your car. Absorbed by carpets and insulation this moisture can add greatly to vapor content in the air, especially as the car warms.
I hope this helps you find your problem. If you have any more questions leave them in the "add comments" and I will check back.
Thank you for using FixYa!
KL
Dec 14, 2009 | 2001 Oldsmobile Alero
Karcher K5.540 2,000 PSI 1.4 GPM Electric Pressure Washer Logo
169 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
