When i start my washer it clicks 2 times and then it pauses itself,just replaced the latch,please help!
  • tom cassidy
    tom cassidy Apr 13, 2015
    Hi Tomasita Rodriguez, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Washing Mach... Master
  • 5,323 Answers
DID U CONNECT DOOR SWITCH WIRES CORRECTLY U CAN BYPASS IT JUST TO TEST THE SWITCH
When i start my washer it clicks 2 times and then  - when-start-washer-clicks-2-times-pauses-fgv1ctnzjgewe3hu2qpqylbk-3-0.jpg
Posted on May 08, 2015
watugot
  • 290 Answers
SOURCE: Kenmore Elite he3 front load washer
What you describe still sounds like a door switch problem but if you can run it through the diagnostic cycle then it should be ok.
The only thing different in starting diagnostics and starting normal cycle is you don't press the start button in diagnostics.
If you know how to put it into manual diagnostics you can check all the buttons to make sure they are working properly.
It is unusual to have 2 different problems at the same time and if the switch was broken, it definately would not start the cycle.
Put it into manual diagnostics and check the start button.
Post back and we will go from there.
Thanks/Mike
Posted on Nov 03, 2007
ronaldsuboc
  • 449 Answers
SOURCE: F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Posted on Sep 19, 2008
Excellency
  • 20 Answers
SOURCE: Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Posted on Dec 10, 2008
blueextc3221
  • 15935 Answers
SOURCE: F DL code on my kenmore elite HE 2 washer
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
SOURCE: I have a whirlpool cabrio washer with F1 error code !wtw6200sw0
looks like a faulty contact maybe. See this site:
http://applianceassistant.com/Washer-Repair/Cabrio-Bravos-Oasis/Cabrio-Bravo-Oasis-Troubleshooting2.php
Posted on Jan 18, 2014
Testimonial: "Thanks everything i needed but can you possibly find me a cheaper control board for the washer?"
Why is control stuck on pause?
Thank you for allowing me to assist you, Friend.
If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Hope this helps! - Z
Aug 17, 2014 | Frigidaire Washing Machines
Always on pause and do not want to start back
Hi benpatoine - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. If fault reoccurs, then it typically means that the unit has a faulty door latch. If you are certain that the door is properly shut, then the latch assembly may need replacing. Consult a professional to assist with the repairs.
Feb 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire frontloader washer stuck on pause
Hello Angela Gilmer - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. If fault reoccurs, then it typically means that the unit has a faulty door latch. If you aren't certain that the door is properly shut, then the latch assembly may need replacing. Contact a professional to assist with the repairs.
Jan 20, 2013 | Frigidaire GLTF2940ES Front Load Washer
Dryer won't spin belt good
Your problem says dryer but the category says washer. I wrote this answer thinking the problem was washer. Sorry but I haven't had opportunity to fix my dryer before so can't help you there. If however your problem is the washer (or is anyone else is reading this), please read on... you should find some ideas here.
First you have to check the error code. If your washer does not have a digital display you have to do the following:
1. press any button to "wake up" the machine.
2. press and hold the start and pause buttons.
3. count the flashing lights.
a) first the five lights plus the start light will flash. Count.
b) then the start light will flash. Count.
4. error code is E +# of times in a + total # of flashes in a and b.
Example: flashes start light plus all five lights 4 times, then a pause, then start light alone 3 times. Error code is E47.
There are lots of error codes but E47 and E43 are both door problems. Check out the following document for a lengthy (but understandable) troubleshooting guide. E47 and E43 both say to do Test 9, which is test the resistance of the PTC. If it's not working then you have to replace the door latch assembly (about $80), if it reads around 1500 Ohms you have to replace the control board (about $250).
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134542000.pdf
First, let me say that I have no idea how to test the PTC but it can't be hard with a standard multimeter (I will be doing this tomorrow with my Dad).
Second, the removal to access the door latch assembly is stupid easy - check out the following YouTube.
http://www.youtube.com/watch?v=prkM2XMoOJk
Third, if you have a different error code just look up the test in the manual document above.
Hope that helps!
Dec 15, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire Affinity front load model #ATF6000FS1, when the start button is pressed it automatically goes into pause mode. I have tried resetting by pressing the "spin speed" and...
"pause" isn't something you can reset exactly I'm afraid. Pause means that the washer door was opened mid cycle so all you should need to do is shut the door to restart the cycle. Unfortunately if it doesn't re-start, it means that your door latch assembly has failed and isn't sensing that the door is shut. You'll need to order and replace the door latch assembly to fix the issue.
It's actually a fairly easy part to replace if you're handy. You'll need to unplug the washer and open the door to start with. Then there is a wire ring around the front lip of the rubber door gasket. Use a flat head screwdriver/needle nose pliers and pry the wire ring off. From there you can pull the gasket back out of the way. Remove the screws going into the door latch from the front and reach behind to replace the door latch assembly.
Make SURE the door strike on the door isn't broken too.
that's only a 6$ or so item.
Here's a site for parts and a video on how to replace it.
https://www.repairclinic.com/PartDetail/Door-Switch/131763256/4547033?modelNumber=ATF6000FS1
Hope this helps you.
Feb 17, 2018 | Frigidaire ATF6000ES Front Load Washer
Washer won't start, makes a clicking noise and than a code comes upF DL
Hi
Thanks for using FixYa. Error “dlf” or f dl means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 29, 2010 | Kenmore Elite 45986 Front Load Washer
WHIRLPOOL FRONT LOADING WASHER MODEL #GHW9460PL0
I have a Sears front load made by Whirlpool. It had a problem locking door. I replaced latch/switch assembly and still would not work. Took top of washer off 3 or 4 screws on back of machine lift up lid and slide back. Make sure washer is unplugged. Presto you can see wiring and control. Unplugged connectors on control and plugged them back in then tried washer and it works.
Apr 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER WON'T START
possible door latch or even the strike on door itself may be broke
Sep 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite HE4t Washer door won't lock
Im assuming that the part number youve mentioned is for the new door latch assy?? Unfortunately the problem could also be in the Main CCU. Ive had several of this design have intermittent door lock codes and not lock the door....It was the CCU in most. This washer should have a full years warranty for parts and labor. Perhaps the sears people didnt understand its still under warranty. I wouldnt want for you to waste your money on the door latch if it is the Main computer. Also you may want to remove the top of the machine and check the wiring connectors going to and from the CCU and the latch.
Nov 25, 2007 | Washing Machines
Washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
