Question about Waterway Pool & Spa
I have a Waterway Insulated wetend pump 1 HP. Model # SD-10-2N11MC It has power to the pump but doesn't work. 118 Volts per wire. Makes no noise but keeps blowing fuses. A Balboa VS501Z power unit.
  • Waterway Master
  • 1,631 Answers
Wet end, connected to an electric motor, makes a pump.
Terminology lesson.
The wires coming into the motor, you said 118 per line, what do you have across both hots?
that is a very common mistake, most people make when checking for voltage. They will check each hot line to ground, and think that they have the proper high-voltage, of 240 V or thereabouts. so, 120 + 120 does not necessarily equal to 40. You could be reading the same voltage back through the motor and getting the exact same voltage on the other hotline. That's why you want to read across both hotlines good you should get 240 V. If you get anything less than that, you have a deadline, or the dead short.
replace the motor.
Posted on Apr 13, 2015
  • 2,402 Answers
You have a short some place or the motor or pump itself is shot or seized causing it to shut itself down by blowing fuses. Could be bad bearings.
See if you can turn the shaft on the motor.by hand with it not plugged in that will tell you where the problem could be. .
Posted on Apr 12, 2015
5 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
  • 6 Answers
SOURCE: Pump makes clicking noise when powered up ?
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Posted on Aug 23, 2009
Testimonial: "Thank You for all of this information and your speedy response. I will run through your suggestions tomorrow and let you know how I made out. "
Coastsider
  • 331 Answers
SOURCE: can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Posted on Apr 14, 2010
  • 8404 Answers
SOURCE: Model #SD-20-2N11CC WATERWAY PUMP (2HP)
Rule of thumb for a 2 HP pump using a 2 inch pipe is between 60 and 80 gallons per minute. Factors affecting flow rate is the distance between the pump and the pool, how many bends and turns and of course the condition of the filter. If you need to meet a specific turn-over rate, use the lower number to determine in the event you sould be called on the carpet.
Low speed? I am sorry. I don't know the rule of thumb on this.
You could install a flow meter, available at your professional pool supply. They are easy to install and not a lot of money. Follow the installation instructions as best as you can.
Incidently, comercially speaking, the 'turn over rate' should be around 8 hours for a public pool. Your jurisdiction may have other standards. Commercial pools should run 24 hours a day at that rate during the open season. Turn over rate means all the gallons of the pool should go through the filter in 8 hours, or all the gallons should go through the filter three times per day. Example: 16000 gallons of water in the pool, your filter and pump should be pumping 2000 gallons per hour. Studies show that it actually takes up to 5 days to get every actual 'chunk' of water to go through the filter, so, many of the 'chunks' of water go through the filter multiple times per hour. BTW, I use the word "chunks" in an effort to better paint a mental picture of what is happening. I am not suggesting your water has "chunks" in it.
Thanks for your question @ FixYa.com
Posted on Jul 08, 2011
Replacing a waterway 56 executive spa pump 3 hp with 4 hp. how do I wire plug into 4 hp pump
The pump motor should have a label on the side of the motor showing a diagram for Common, High speed, Low speed and the right positions for the connections.
Common is always the white wire
High speed is normally red
Low speed is Black
Green wire is always green
Oct 02, 2015 | Waterway Pool & Spa
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
How do I set the Waterway Champion Pump for 115 Volts? I have the same problem, just installed and it runs for a bit then shuts off. It was mentioned that the pump is usually set for 230, so how do I set...
The voltage is not optional. What voltage are you plugging the pump into?
If you are plugging it into 115, the pump must be set for 115.
If you are plugging it into 230, the pump must be set for 230.
Usually there is a wiring diagram on the label on the pump body or if you remove the end cover, there may be instructions there. There may even be a switch or terminal that states 115 volts and another that states 230 volts.
Gary
Jun 29, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
My 4.0 hp waterway excutive pump works, the shaft spins, but no water movement, i checked for airlocks, could it be the grey propeller inside the wetend thats not working? is it worth a look inside the...
Thank you for posting your question here on Fixya.com.
Yes...you'll likely find the impeller body has broken away from the motor shaft so even though the motor turns the impeller is not. Replacing the impeller and the seal are not to hard but you may want a shop to do it if you are not familiar with seal replacement. While they have it they can make sure the motor bearings are still OK since the most common reason the impeller breaks is a seal leak that leads to motor shaft and possibly motor bearing damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Mar 17, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
I just bought this pump and just bought a new wetend. Everything was the same as I had before. I hooked the wetend to the pump just like before and installed it into the spa. When I turned on power,...
The wear ring on the impeller can cause all these problems. It seems natural to put this on the impeller with the wide side tward the impeller but it goes on with the wide side out so when the pump starts the ring slides forward and seals the pessure side of the impeller from the suction side. With this in wrong your water will just circulate inside the pump rather than going back to the spa. I hope this helps.
Dec 16, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
1.5 hp waterway champion pool pump issue
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
Jul 28, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Good Luck
Kurt
Mar 18, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Pool & Spa Logo
90 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Mike
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
