Question about Vacuums
The vacuum has a lack of suction compared to when we bought it 6 months ago
    Master:
  • Vacuums Master
  • 717 Answers
HI, it's Jim from Crucial Vacuum!
If your vacuum is experiencing a lack of suction there are several places you can check to help your vacuum operate at its peak performance.
Check out your brush roll. Look for any noticeable debris, and be sure to manually rotate the brush roll to unearth any hidden clogs that may be behind your brush roll. If you see carpet fibers, or strands of hair remove these with a razor, or scissor.
How do the bristles look on the brush roll? If they're loose, or look worn down then it may be time to replace the brush entirely.
Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. If your brush roll isn't operating properly it won't be able to pick up dirt and debris.
Be sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction for your vacuum.
If you're also getting little to no suction from your vacuums hose and attachments then check your vacuums hose for a clog. Stretch it out as far as you can to unblock any clogs. If there is a clog in a hard to reach spot try using a broom handle to reach the area.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Apr 13, 2015
  • 1,921 Answers
Clean all filters and if there is a hose it could be partially plugged as well. Take hose off and shove something like a dry water hose through it.There is usually a filter back of the dirt bag as well. If it has been used to vac up drywall dust the dust bag will plug up before its filled as the dust is so fine it will plug up every thing on the vac. Really clean every thing and it will work better.
Posted on Apr 12, 2015
My Electrolux Precision Brushroll Clean Bagless Upright Vacuum, EL8807A Won't Start. I Plug it in and turn it on and nothing ... no motor sound no suction, it has a burn smell. The brush will roll but the...
The burn smell means you should take it to a qualified Electrolux repair facility. It may be an electrical issue and could catch on fire if not repaired properly.
Oct 25, 2013 | Electrolux Vacuums
DC17 suction motor stopped
It could be that your cyclone needs to be replaced. Depending on how the unit was cleaned (the cyclone in particular). Some people who service these machines wash the cyclone with out completely dismantling it, they just fill it with water and shake stuff out of it. This can cause debris inside the cyclone to become lodged causing clogs. If after checking for clogs and if your changeover valve is working (the piece that moves back and forth on the side of the machine when you pull the handle back to vacuum carpets) and the machine is in the upright posistion and the hose doesn't work, then you probably have a cyclone problem.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 10, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction cuts out, no clogs found in any of the inlets. It's an LG V200R, 4 months old. Returned it to LG twice and it still happens after a couple of uses. Is this a design flaw in the vacuum? Do you...
I bought the lg kompressor 2 mo ago. Made hissing sound and no suction to canister, but the hose had good suction. The inlet was clear, but there was a clog up inside the vacuum between the inlet at the beater bar and the lower hole that empties into the canister(very hard to find). Use a wire hanger to clear it out. just keep jamming it up there and it will clear eventually. There is a clog somewhere, you just have to find it.
Sep 04, 2011 | LG Kompressor Upright Vertical Cyclone...
There is no suction at all when using the vacuum.
Replace the bag or if it has a dust container, empty the container. If you have done this, turn unit on and place your hand over the mouth of the unit to see if there is any vacuum (suction). If not, then the hole or hose is probably plugged with dirt/hair or something else. Disconnect the hose from the unit and blow through it. Airflow should be easy with no resistance. If you encounter resistance (it is difficult to blow air through the hose) you have to remove the debris blocking it. Take a coat hanger, unravel it into one long wire and make a VERY SMALL hook at the end. Push this down the hose and try to hook the ball of debris and pull it out. You may have to do this several times to clear the hose.
Aug 20, 2009 | Electrolux Vacuums
New vacuum doesn't pick up....
bockage on the pipe bend.open and clean out.
Jul 19, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Jun 04, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
I HAVE A FANTOM VACUUM CLEANER MOD.#F1205400. I PURCHASED IT ABOUT 6 OR SO YEARS AGO.IT WORKS PERFECT,AS FAR AS SUCTION, THE ONLY PROBLEM IS ABOUT 2 MONTHS AGO,SOMETHING HAPPENED TO IT AND IT GOT VERY...
You probably have a bad motor bearing. I don't know if the motor is available now or, these older Fantom's are obsolete along with most of their parts.
May 01, 2008 | Vacuums
Not working
If only 2 months old, take it for repair as it is under warranty.
Mar 28, 2008 | Dyson DC18 all floors Bagless Upright...
Vacuums Logo
71 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
