ScanSnap iX500 Won't stay on
I have it hooked up to a mac with OS X 10.75 and i have to hit the start button several times - it lights up and turns right back off again. I have unplugged, restarted everything... still won't work. I thought the scan snap software might need updating - and it's trying to do a firmware update - but it can't because the scanner won't stay on. Everyone once in a blue moon -it will stay on and scan something... It worked perfectly up till now...
5 Suggested Answers
  • 121 Answers
SOURCE: Imageteam IT3800 scanner won't hold the config.
Does the scanner use a small battery to keep the stored information? If it does, this battery might be defective.
Posted on Mar 09, 2007
  • 3 Answers
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
are you using usb keyboards if so set the scanners to stand alone keyboard wedge you will find this in the manual. if this is not the case it could be that the scanner is set for a different keyboard type just set the scanner for keyboard wedge emulation. hope this helps Pete
Posted on Aug 23, 2007
SOURCE: scanner failure
buy a new printer
Posted on Jan 09, 2008
guide2u
  • 461 Answers
SOURCE: HP photosmart all in one doesn't scan anymore
hi,
not sure what is you printer model, but below link might be useful to help your solve your problem...
http://etech.maiila.com
good luck
Posted on Nov 19, 2008
Scanning duplex I get a line down the righthand side of all alternate pages?
With very limited information, I suspect if you observe closely on the side that has the line printing you will find a dark smudge on the glass. If this is found you should be able to use a little rubbing alcohol on a clean cloth an remove the smudge.
Mar 28, 2016 | Fujitsu ScanSnap iX500 - document scanner
Vertical line appears on scanned item
Clean the glass and wipe any residue off the rollers.
Aug 14, 2014 | Fujitsu ScanSnap iX500 - document scanner
My ScanSnap has worked flawlessly for years. I just tried to scan and got the following message: undefined error occurred.(0xffffdcf7) Won't scan. Tried to reboot - no luck. Let me know...
The same thing happened to me. In a nutshell, you have to install new drivers. Have you recently upgraded your system to SnowLeopard or Lion? I did, and that's what went wrong.
To do:
1. Make sure you have the latest ScanSnap manager: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac.html
Install that.
2. Get the Lion update: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac-mg22.html
Install that.
3. Open the new ScanSnap Manager (v 2.2). Delete the old one from your dock, so you don't get confused.
4. Scan away.
Aug 06, 2011 | Fujitsu ScanSnap S510
Hi,\r\ni have a problem with my macbook air when
Try restarting your computer while holding down the X key. This may force the computer to start up using your Mac OS X system. If it does, release the X key, then open System Preferences and click Startup Disk. Make sure your Mac OS X system is selected. If you are unable to start up using the X key, restart your computer and immediately press and hold the Option key. Release the Option key when icons start to appear in the center of the screen. Select the Mac OS X system disk, then click the forward arrow to continue starting up.
If the above attempts to reselect your Mac OS X startup volume are unsuccessful, try resetting PRAM. Shut down your computer, then turn on the computer and immediately press and hold Command-Option-P-R until you hear the startup sound for the second time. Open System Preferences, click Startup Disk, and select your Mac OS X volume.
Hope this helps. If none of these options fix your problem, bring your computer to an Apple store, they are always very helpful and almost never fail to fix the problem!
Mar 11, 2011 | Apple MacBook Air
My macbook won't turn on. Instead the screen stays black and a loud beeping noise comes one until i turn it off. What to do? I've already tried command contrl R/P and it still doesn't work.
Tones before the Happy Mac or Apple logo means that during the start up process (when Mac checks Hardware) it found something wrong. I have seen this with bad memory, and crashed Hard Drives.
Insert the original CD that come with the machine and hold down the C key and then hit the power button.
Then try to reinstall operating system.
All your data will be there. You may need to enter program serial numbers again but Music. Docs etc should still be there.
Strong believer in TimeMachine. this free software from Apple has saved my life several times.
Aug 18, 2010 | Apple MacBook Mac Notebook
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
May 26, 2009 | Fujitsu ScanSnap Manager
UMAX Mirage IIse Running on MAC OS
I had the same problem. I turned off the scanner and unplugged the transparency unit from the back of the scanner and restarted and it is working fine now. Hopefully this works for you as well.
Sep 22, 2007 | Umax Mirage II Flatbed Scanner
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
