My adjitator stop spinning how can I fix it? without calling someone to repair it
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check belt
Posted on Apr 12, 2015
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: error reading LE. How can I fix this without
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Posted on Jan 27, 2011
My simpson aquapulse 513 5kg heavy duty machine, spins washing into balls and then stops, what must I do to repair this
You will probably find the agitator is spinning but steel bowl isn't. Either brake release is not working or clutch problem. Not an easy fix. Best to get someone out to repair it.
Nov 12, 2016 | Simpson Washing Machines
Adjitator won't work
if the adjitator and the spin cycles do not work the coupler between the motor and the transmission is at fault
May 23, 2010 | GE WJSR2070B Top Load Washer
We just bought a Maytag Bravos washer. We were
it should be very tight if you look down the middle of the adjitator it should have a aloy screw that should be done up very tight
Apr 24, 2010 | Maytag MAT13MN Top Load Washer
Our washer does not spin. It vibrates, but when you open the lid, it is clear that nothing has moved.
Does the washer adjitate well during the wash cycle. If the washer fills and pumps oput the water but does not adjitate or spin well the coupler that couples the motor to the transmission is stripped and worn our.
Nov 28, 2009 | Cars & Trucks
Washer wont agitate, but drains and spins ok
hello. i can assist you. when a washer won't agitate, one of several expensive repairs are in order. If your washer is more than 5 years old I recommend replacing as opposed to repairing. That said if you want more information on what might be wrong get back.
Nov 03, 2009 | GE WBSR3140DW Top Load Washer
Is the washer worth fixing? My washer stopped
Without looking at unit would most likely be door latchlock or motor control board that is the board that is located at bottom of unit under tub/if someone told you it needed more than one board that is highly onlikely/don't think i every changed more than one board at a time. Questions czerney@msn.com
Oct 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Wahing machine will adjitate only
check your lid switch and check your cold water inlet
Nov 25, 2008 | Kenmore Washing Machines
Whirlpool gold UIltimate care heavy duty super capacity washer
Well you can check the capacitor with a meter for farads, but it sounds like you have a clutch and/ or gearcase failure causing the motor to overheat. The second thing to do is unplug the washer and check the timer. I would right after the agitation to inspect for heat and burnt connections.
Oct 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
