Question about Craftsman 10" Radial Arm Saw Table Electronic Controlled 2.5hp 1ph 120vac
Saw just quit.Reset didn`t work,are there fuses?
    Genius:
  • 1,585 Answers
Dosent seem vg saw
Posted on Apr 12, 2015
  • Craftsman Master
  • 2,027 Answers
Are you plugged into a GFI? If so you may need to set the GFI receptacle also plug it into a different plug in and see if that works. In saying that I bought the same one and burnt out the motor in less than one hour from purchase. with not cutting any more than five pieces of pine board. They did replace the saw for me.
Does my 20" DeWalt scroll saw have a reset switch?
check if there is a reset on the motor..usually push to reset.
Jul 29, 2014 | Dewalt DW788 Heavy Duty 20" Variable Speed...
My Ryobi portable table saw BTS20 just quit working in the middle of a cut.
me id look at the under side of saw , id bet the saw just tripped out in use and needs to be reset , id also bet the reset is marked in red some place around motor
Dec 12, 2013 | Ryobi Table Saw Manual
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
I have a dewalt table saw...wood got stuck on a cut...motor stopped..switched saw off ...removed wood ...saw wont go...changed fuse in plug ..still nothing
If the fuse is now good then you could have tripped the safety and need to reset it, if it has one installed. Or the power cord or the motor are the problem.
If you didn't smell hot or burning electronics smell then it will most likely be the safety aka blade or finger guard. If you did smell hot electronics then it may have burned the power cord or seized the motor. Your user manual will show you where and how to reset the safety. Any local repair shop or tool shop should be able to guide you through this as well as pointing you towards a repair shop if needed.
I've stalled mine a few times and have just reset the fuze and away it goes again. It sounds like you might have done a bit more to yours.
Sep 06, 2011 | Saws
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
My saw will start. It has always run quite well,
If it hums but doesn't turn it is almost certainly the starter capacitor which is fairly easy and cheap to replace . Usually a metal or plastic cylindrical object attached to the motor or sometimes inside the switch housing. Buy a replacement from Electronics store or from the makers of the machine.
If it does not hum and you have checked fuses then the switch is probably the trouble and switcheds dont like dusty environments at the best of times.
Jun 02, 2010 | Craftsman 10" Table Saw
Saw quick working suddenly, maybe blown fuse
Your saw will have a reset button that may be black in color but should not have a fuse
With the power off push down in the reset button you may or may not hear a small "click" plug it back in a give it a try
Pushing them to hard will cause an overload and they will quit
give it 5 minutes to cool of and resetting should do it
Mar 08, 2010 | Hitachi 12" Compound Miter Saw with Laser...
Does not turn on. The wood was at an angle and jammed when it quit working
Hello. I recommend that you check your circuit breaker or fuse which is in the house panel and feeds the outlet that your saw is plugged into.
I believe that you will find that you solution is to reset the breaker or change the fuse.
Nov 28, 2009 | Craftsman 10" Table Saw
Fox Shop Table Saw won't start
Your saw has a reset button inside the magnetic switch assembly. You may need to pull the cover off to reset it. Unplug the saw first.
Consult the user manual p47 at this link, if you don't have yours handy. http://edge.woodstockint.com/manuals/w1711ext_m.pdf
If that doesn't do it, look to a breaker in your fuse box.
i hope this does the trick. If so, please take a sec to rate this post. Otherwise, let me know what you discover and we'll try to sort it out!
Mar 26, 2009 | Shop Fox W1711EXT Table Saw
On Craftsman tablesaw/model 137.248830, was ripping some 2x4's, went to make next cut and saw wouldn't turn on. Pressed reset button, but that didn't help. Button seemed "soft". Cleaned out sawdust from...
I just bought this saw used off of e-bay. Got it home check to see if it would run, It did. The next day got the saw out and nothing. By passed the breaker and the switch and it ran fine. Ended up taking the switch out and apart I found that there is a rocker inside that either rocks in one direction (off) or the other direction is (on). the on side has a contact similar to a points contact on an older vehicle. Mine had some saw dust between the contact thus no power. wiped it out and the saw was fine.
Jan 19, 2009 | Saws
Craftsman 10" Radial Arm Saw Table Electronic Controlled 2.5hp 1ph 120vac Logo
183 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
