Question about Electrolux Washing Machines
My electrolux front loader model gltf2940fs1 will not fill after door locks it is not doing anything
Timer continues to count down but washer is not doing anything. I unplugged it and plugged it back in but nothing is happening. No error codes
    Genius:
  • Electrolux Master
  • 1,585 Answers
Check inlet valve
Posted on Apr 12, 2015
Hi there I have a Electrolux Front Loader EWF1074 that is not filling. I have replaced the water inlet valve but its still not working, whats my next step?
What controls the valve?either a timer or a control board .possible the door switch has failed or moved , not telling it that it is safe to fill .
Apr 09, 2018 | Electrolux Washing Machines
Samsung WF42H5400 AW/A2 Washer was briefly unplugged, then plugged back in. Now, it will not power on. Any ideas as to why?
hi Peggy.
Main reasons a washer will not start (either front or top load):
1. Power breaker off, washer not plugged in.
2. Lid switch faulty, door switch faulty.
3. Start switch and or timer faulty.
4. Washer motor faulty.
5. Main control board faulty or shorted.
Power to Washer
Be sure the washer is plugged into the electrical outlet in the wall. Also be sure the breaker switch in the breaker box is turned on. If you live in an older home your box may be called a fuse box. If so, make sure the fuse is in good working condition.
Door Switch Strike (Front Load Washer)
The door switch is a safety feature on front loading washing machines. On front loaders, the door switch must be closed and the door must be locked. If this switch malfunctions, the washer won't start. This switch is in the door frame of the washing machine where the door shuts. If you suspect the door switch is causing your washer to not start, carefully check the strike where it engages into the door lock assembly. Be sure the lock is working properly by keeping the door shut and locked shut. You can check the door switch for continuity with a multimeter. Be sure to disconnect the power to the washer when you check for continuity. If there is no continuity, replace the door switch.
Lid Switch (Top Load Washer)
A lid switch is a safety device located under the lid on top load washers. This lid switch will not let the motor operate when the the lid is open. If the lid switch is faulty, then the washing machine will not start. It may fill with water but will not spin if the switch is faulty. Some lid switches on top loaders also control the water inlet valve. In some top load washers, if the lid switch is bad, the washer will not fill with water. The lid switch is under the lid. There is a pin or pusher attached to the lid. This pin or pusher (when lid is closed) will press the lid switch. If your washer will not start, be sure the switch is being pressed. If the lid switch is being pressed but no power is being supplied to the washers motor, then the switch is most likely bad. To test the switch, turn off power to washer and remove the wires from the lid switch. Check the switch for continuity with a multimeter. If there is no continuity, replace the lid switch.
Start Switch and Timer (Top Load Washer)
The start switch timer on top load washers is part of the timer. This starting switch is turned on by pulling out the timer knob. If after pulling the timer knob the washer will not start, you can test it for continuity with a multimeter. Remove power from the washing machine and find the timer contacts. Some top loaders have a start switch that is a momentary contact type of switch. This switch will be located on the control panel. You can also test this switch for continuity with a multimeter while pushing the button in. Remove power from the washer before testing for continuity. If there is no continuity, replace the start switch and or timer.
Timer Knobs
Sometimes the timer knob wears out and cannot properly engage the timer shaft. If this is the case, then the knob is at fault. The knob cannot grip the shaft therefore is unable to turn the machine on. A worn knob will cause it to slip. Turn off power to the washer and inspect the back of the timer. Make sure the timer shaft engages the knob when it is pulled in or pushed out. If the knob is worn, replace it with a new one.
Drive Motor
Both top and front load washers use a motor that spins and agitates. (A top load washer uses a reversing motor) The motor spins in one direction to agitate and the other direction to spin. When the wash motor will not turn on it may be faulty. If the motor makes strange humming sounds then the motor may be at fault. To test the motor, remove the belts and try to start the motor. If it runs then you know something else in the washer is causing the issue. On newer direct drive washers, you will have to disconnect the pump and the coupling to the trans. If the direct drive motor turns on, then then you have a transmission issue or possibly the pump. If the direct drive motor won't start then it should be replaced. On front load washers the motor drives the washing basket with a ribbed belt. Remove the belt and try to start the motor. If the motor runs, then be sure the basket turns and doesn't have anything stuck or jammed between it and the outer tub basket.
Main Electric Control Board
The control board controls every component in your washer. If the main control board does not properly control the motor, the filling valve, the drain motor, or the door lock, the washer will not start. The only way to determine if the control board is at fault is to visually inspect it. Check for burned areas or any component on the board that may look burned or damaged. If you find burned areas or components on the control board, remove and replace it.
or read up more at this link.
samsung washing machine will not turn on Google Search
Dec 12, 2017 | Samsung Washing Machines
Electrolux washer playing up!
Remove the top panel, there should only be 2 or 3 screws on the back of the panel, then slide the top panel back about 1/4 inch and it should lift off. Look to see if the belt has come off. Post your results back.
Jun 28, 2013 | Washing Machines
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
Electrolux front load washer fills but does not wash
Hello - Either you have a communication error from the main control board or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. Contact a professional to accurately diagnose the washer.
Oct 09, 2012 | Electrolux Washing Machines
My electrolux 1320140-63/3 front loader washing machine has stopped working. the timer still starts and counts down but does not start other than to fill with water. any suggestions please
The output from the timer to the motor has failed and so it seems that the timer program controller unit is faulty. You will need to confirm the failure of the output using a multimeter. Also of there is power to the motor, check if the motor is warm or hot . If so the capacitor to the motor can be a suspect. Also failure of the motor winding's or a mechanical jamming cannot be ruled out. check the free movement of the drive.
Jan 07, 2012 | Electrolux Washing Machines
Washing Machines Logo
64 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
