Question about GE Refrigerators
Have a refrigerator question
The refrigerator shut down twice in two week period both times I was able to restart using turbo cool button. The led light was flashing showing err message. do I need a service call. it working now. thank you
  • GE Master
  • 473 Answers
Sounds like you may have an intermittent problem with the main mother board which controls almost everything in the refrigerator. It is a computer type board on the outside back wall under a cover plate about 8 X 10 inches with screws all around the edge. If by chance your fridge is less that an year old I would call for warranty service.
Posted on Apr 13, 2015
How do you how to turn off turbo cool on ge refrigerator gne25jmkes
Pushing the TC button a second time turns off the turbo cool. Otherwise it will time out on its own.
Aug 12, 2016 | GE Refrigerators
How do I keep my cz550 running for longer than 3 minutes before cutting off
if this a diesel engine with a controlled shut down after turning the key off, there is no need to extend the idle period as 3 minutes is ample time to allow the turbo to slow down and cool down
understanding how a turbo works is the key to the answer as the turbo is already cooling down and slowing down as you are coming to a stop and the extra 3 minutes is a safety period to complete that process
If you are concerned about a turbo failing then there is an accumulator that can be purchased after market that is fitted to the oil circuit of the turbo
It has a bladder in a case and oil pressure pressurizes that bladder so that when the engine is stopped , that oil is pushed back through the turbo bearings It can be fitted to any turbo engines
it is particularly useful for engines that are subject to stall conditions such as 4wd that are operating in conditions where clutch operations causes the engine to stall
however to answer your question , there may be a small adjustment in the side of the timer box or in the box that can be reset to longer time
however long idling of an engine is not good for the wear factor of the engine
Nov 12, 2015 | Cars & Trucks
Why does my Dell 1510X Projector not shut off when I push the off button ?
This projector as with most high power projectors will have a cool down period for the lamp once the power button is pushed from on to off. For this model, the cool down period is 120 seconds after which the unit will fully power down. You can override this cool down period by pushing and holding the power button for 1 seconds. If you use this procedure though, you should not power up the projector again for at least 60 seconds to allow the internal temperatures to stabilize.
Feb 27, 2015 | Dell 1510X Projector Projector
I have a ~4year old Dometic RV refrigerator that does not start cooling when started after periods of being shut off (as little as 2-3 days). When I turn it on I can hear the fan start but after 2-3 hours...
ammonia absorption refrigerators need continuous heat either by
a heating coil powered by a transformer or, a propane flame
check/replace your gas thermocouple or, transformer to the heating coil located on the refrigerator back
Aug 21, 2013 | Refrigerators
Code for sony tv
Make sure your TV is on.
press "TV" on your sky remote
hold down both "SELECT" and then "RED" button until the little LED blinks twice on your sky remote. (should be for about 2 seconds)
press "TV" again
enter the code "0000" on your sky remote
the little LED should blink twice again. (if it didnt, restart the process)
if it had blink twice, then press the "STANDBY" button on the sky remote - your TV should turn off. (if it didnt, restart process again)
if it did - press "SELECT" the little LED should blink twice again, and hey presto - you is programmed wink.gif
Apr 25, 2013 | Radio Shack (15-2147) Remote Control
The air conditioner for my 2001 volvo v70 turbo will shut down periodically while running in hot weather or when running while the vehicle is stopped (traffic) for an extended period. Shutting the AC off,...
There may be a restriction in the plumbing of the air conditioning system that is making the high side pressure too high, thus shutting off the a/c for safety reasons.
Or, the refrigerant pressure on the low side is too low, caused by not enough r134a refrigerant in the system.
Aug 13, 2010 | 2001 Volvo V70
Samsung frig stopped cooling-
most new fridges have a self defrost mode once or twice a day because the coils ice up if it collects alot of moisture. it shuts the compressor down and turns on a heat coil to defrost (which can take up to a half an hour). usually on a timer that is adjustable.
Jul 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Difficult to start again after warm up engine.
give the engine a minute or two to cool down before turning it off. This cool down period allows oil to circulate and cool down the bearings in the turbo. If you shut off the engine immediately after hard driving, the oil can gum up around the hot bearings and create problems down the road.
Hope this helps
Thanks for using Fixya
Have a nice day!
Mar 05, 2009 | 1995 Honda Civic
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
