Question about Tools & Hardware - Others
I was using my campbell hausfeld model 504000when a nail got stuck. I removed the nail and now the gun does not work
  • 744 Answers
Does the campbell hausfeld model sb504000 2 inch nailer/stapler need an external air to get started?
Sb504000 works just fine with pressure range from 60 to 120 psi depending on material. Any small compressor will work great. Using the gun at max pressure will shorten the life of the gun. Best practice is to set pressure to just under 100psi for most work and increase pressure when nailing hard wood. Using at max pressure will strain the driver and the lower part of gun (screws that hold nose to body). Some hard woods will bend an 18 gauge nail. Good luck with your gun and have fun with your projects.
Aug 11, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
I have a 34 degree Campbell Hausfeld framing gun and after connecting it to the air compressor and with 125 lbs. air pressure I click the trigger and it doesn't fire.
May just be a stuck headvalve or safety is not pushing trigger pin all the way into trigger valve. If trigger pin is being pushed up all the way into valve, check headvalve. Remove head and try to press in headvalve with thumbs. If it feels stuck, apply air pressure to vent hole on gasket surface to pop it out. Apply silicone paste lube to surface and orings. Re-install and check. If head valve was not stock, lube and replace head.
Feb 01, 2011 | Campbell Hausfeld Round Head Framing...
Gun fires, leaves good indentation, no nail. WCE working properly, took head apart to look for jam but nothing in there and am using compatible nails. Also oiled it but no luck. Was working fine doing...
Remove nails and use thin tool to push driver all the way up to top of cylinder. If the gun fires one nail then skips, the driver is not returning to top of cylinder. If no nails fire, then nails are not feeding into proper position. Driver must return to top to allow nails to feed into position. Most common problems are bent driver, worn piston oring and bad batch of nails(head too large). Good luck
Jan 14, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
Two nails at a time and one of them only goes in one quarter of an inch.
Campbell hausfeld makes a 21 and 34 degree angle nail gun. The most common mistake is the wrong nails are being used. Some after market nails will not work correctly in some guns. Check to see if the gun accepts wire welded or paper clip nails. Check the angle required. Also be sure the gun is oiled if it is not an oil- less gun. hope this helps.
Jan 11, 2010 | Campbell Hausfeld Air Tools & Compressors
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Cambell-hausfeld framer
its double firing, after firing gun pull back, what is happening is when you fire a nail your pushing the gun back onto the wood and its putting another nail in
May 08, 2009 | Campbell Hausfeld 2" 18GA Brad Nailer
Will model no. ifn21950 shoot paslode 2
I would not recommend. Contact Campbell Hausfeld .com and order nails. You could damage your nail driver plunger if not careful. Plead rate . Thanks
Mar 27, 2009 | Campbell Hausfeld Tools & Hardware -...
Campbell Hausfeld NS2190MVRB 21 Degree Round Head Framing Nailer is jammed. How do I clear it?
Remove any nails in the magazine, and you can carefully take a pin pinch of a size that fits into the nose (where the nails come out). Try to carefully tap the driver back into the gun.This will sometimes clear the jambed nail. If the driver is severely jambed you will have to dismantle the entire unit to separate the driver from the nose of the nailer.
Mar 24, 2009 | Campbell Hausfeld Tools & Hardware -...
Driver wont retract
check to make sure the head bolts are tight on the top, if they are it probably needs a rebuild kit from campbell housfield includes orings for the piston, gaskets ect. and instructions
Jan 18, 2009 | Campbell Hausfeld MP292000AV 1/4 Inch...
Tools & Hardware - Others Logo
67 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
