Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Maytag neptune dryer mle2000ayw takes two cycles to dry
Taking multiple cycles to dry a load
    Genius:
  • Maytag Master
  • 1,585 Answers
Clean filter
Posted on Apr 12, 2015
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer takes a long time to dry clothes
your timer is the problem if its not moving
which can be expensive
60-80.00 dollars Dryers are cheap enough to buy a good used one
Jun 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer is taking over an hour to dry a load
Check the exhaust vent out back of dryer to see if exhaust pipe going outside is crimped or blocked. Let me know if air flow is better if pipe is pulled off back of dryer. Thanks, Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
